carldc
Ok, that makes sense. Now, that would also mean that battery life on the phone would be worse, right?
If you are always next to your phone then you will be using Bluetooth, and not cellular for your connection to the phone. In fact I believe the cellular network gets turned off when you are in Bluetooth range.
So basically you are using a lower power method of communicating.
I suspect that being at the edge of BT range with both on might be a battery killer because it is swapping back and forth a lot. But I've done no testing of that.
I can answer that: it's not LTE. Support for LTE is not built into this iteration of the Gear S, but now that LG will be selling an LTE watch, Samsung may follow suit.My AT&T shows "4g" when using the data radio but I don't know if that's 4g or 4glte and nobody at AT&T seems to know which one either.
Thanks.I can answer that: it's not LTE. Support for LTE is not built into this iteration of the Gear S, but now that LG will be selling an LTE watch, Samsung may follow suit.
I was getting 24'ish hour battery life until the upgrade. Now it's horrible. Have had it go dead after 10 hours.thats weird got up at 9 and by 3 mine was dead battery life is shocking no way people are getting 20 hours
I'm probably preaching to the choir but have you tried uninstall the Gear app then install again? That's weird that the Gear 1 didn't work with it because I thought they had unified it to work from Gear 1 through S. A couple of Gear app updates ago I had 2 Gear apps on my phone after I updated it until I rebooted my phone then the old one disappeared. Same icon, same look when opened. I had a shortcut (not true shortcut but I don't know what you call it when you drop an app icon on your home screen) for the old one that also disappeared and I had to a new one back on. There were a ton of complaints about it and my last update was a few days after that. Mine has been fine since the last update .In my case, I only connect it to my phone to sync up run and sleep data, then use it in stand-alone mode. The software on my Note is the problem. Either the latest update that was pushed to it causes it to drain my poor Gear S battery, or the fact that I bought a Gear 1 a few weeks ago and had to install some other Gear software update in order to even get the Gear 1 set up. Something funky is going on.
I miss notifications from my Note on my Gear S, but I mostly bought it for its stand-alone capabilities, and those still work. Stand-alone and unconnected, I get about a day of battery life even with location on and data on, and a daily 1-1.5 hour run I track via GPS and Health app.
I get a solid two days of use, and if I turn it off at night while sleeping, 4 1/2 days!
No wayyyyy!I get a solid two days of use, and if I turn it off at night while sleeping, 4 1/2 days!
Today is Saturday. I haven't charged mine since Wednesday night. I'm also turning mine off when I go to bed. It's been connected to Bluetooth the whole time, never standalone, haven't used the browser any this charge, auto brightness but mostly inside, GPS off, Wi-Fi off, only replying to texts and a few composures of them. I haven't played any games or anything else that uses cpu and screen for long periods. I'd consider my usage over the last few days as light. My clock is Low Energy Clock.No wayyyyy!
That is quite impressive. For me, battery is down 50% from 100% after just 30-45 mins at gym with music (mp3) playing.Today is Saturday. I haven't charged mine since Wednesday night. I'm also turning mine off when I go to bed. It's been connected to Bluetooth the whole time, never standalone, haven't used the browser any this charge, auto brightness but mostly inside, GPS off, Wi-Fi off, only replying to texts and a few composures of them. I haven't played any games or anything else that uses cpu and screen for long periods. I'd consider my usage over the last few days as light. My clock is Low Energy Clock.
No I don't ever have that onwith always on mode or motion?
