How to ONLY use phone's number for both phone and Gear S?
John409
3
In the manual it states "If a Bluetooth connection between the two devices is not available, outgoing calls
will only be made from the Gear." that blows
Sammuel1973
987
I know, there got to be a way around it. If not now, hopefully soon. I just don't want to give out my 2nd number.
tl600f4i
Active member
Jan 18, 2014
29
On Verizon, I've confirmed that on cellular/no Bluetooth, my texts come from my cell phone's number but outgoing voice calls has been confirmed to come from the gear's phone number. I rarely make outgoing calls anyway so that doesn't bother me at all since texting works just fine.
dorrien12
539
On AT&T without Bluetooth and on mobile; outgoing calls AND outgoing text came from the Gear S number, try sending one and see what happens.
jlczl
780
I've been using google voice for years so I have a google alias number for all my frequent contacts. So I can call them and text them from my gear s watch using my number that everybody knows which is my Google Voice number. Plus they don't have to wait forever when they call me for the call to be forwarded to my watch because it will ring my watch and my phone at the same time.
dorrien12
539
I just set up my google voice last night. And I see the option to have it forwarded to more than one number. Let's say the number I set up is 123.
1) Add my Gear S number?
2) Should I keep the voicemail going to my carrier or to Google voice (transcription stinks but I do like that it texts or email me, does that get better over time?).
3) Then give everyone my google voice number (123) and that will ring both whether I'm bluetooth connected or not?
4) How about when I need to call out or text, will that show coming from the 123 number I set up or the Gear S original number?
5) How about when I leave my phone at home?
6) What settings should I have for Blutooth/ Remote, etc.
jlczl
780
Yes, also add your cell phone number.
I have it go to Google Voice. Transcription quality varies. It has a lot to do with how clearly the caller speaks.
Yes, as long as you also added your cell phone number to Google Voice.
It will show up as your GV number if you call people to their Google alias number. You get their Google alias when they text you to your Google Voice number. Since I've had GV for years I have stored all my frequently called number's Google alias. This is the part that will require time to build up depending on the number of contacts you frequent.
You can be remote connected to receive emails and other notifications. You don't have to be remotely connected if you just want to receive calls and texts because GV is already forwarding those to you regardless.
If my phone is on me I'm connected by Bluetooth. If it isn't I'm connected remotely. If I don't care to receive email and other notifications I turn off my phone and still receive calls and texts to my watch just like any other phone.
dorrien12
539
Thanks soooooo much for answering all my questions the way you did. Just two more...I think.
With this last option with your phone OFF,
A- because you used GV, your calls and texts are still being forwarded to the Gear S like usual. And
B- if you decide to then contact someone by phone or text as long as you use their google alias number then it will look like it's coming from the number I set up (the GV 123 number I gave everybody), correct?
John409
3
I know it should be rooted soon but if the network isn't capable then we're screwed. how could Samsung Screw up a "companion" device with the best feature you could have. I'm not giving out a second number to everyone I know.
Sammuel1973
987
Excuse me for being confused. I am tempted to set up a GV account just so that when I call out and text from my watch that my phone number shows up, not my watch number. I have a few questions:
When prompted to choose a GV number, shouldn't that be my cell phone number? I mean, if I have to choose a new number for my GV, wouldn't that be a total of 3 numbers: cell, watch, and GV? If I should choose a new number, wouldn't I have to tell friends of that new number, the same way otherwise like my watch number?
jlczl
780
Yes
Yes
jlczl
780
You are correct. When you setup your GV and choose a number you will have 3 numbers. It is a pain at first because you have to give everyone your new number but once it gets out you will no longer have to give out different numbers even if your main number changes or you get another watch number or whatever because you will just change your settings in GV again.
I believe you can port your existing number to GV but I never did that because I was fine just getting a fresh number and starting from scratch.
Sammuel1973
987
Cool, thanks. So can you confirm and explain how when you call or text from your watch that your GV number shows up instead of your watch's number?
jlczl
780
I don't mean to be rude but I've already done that in this thread. Please read the posts above for your answer.
Sammuel1973
987
No, you are not rude, in fact helpful and patient. Yes, I reread your posts. At this time, I am going to stay put and not use Google Voice. Depending on any possible future update, I may need to give out my Gear number instead. Thanks though!
jessphoto16
18
Hi guys, quick question... is this a connection with bluetooth only or do you already pay for the seperate watch plan? When I disconnect from my bluetooth it shows connected by watch only. Im confused on the remote connection. To me it sounds like you do not need a second line for this, as it uses your moible plan. I reread the manual mult times but not clear on this. Can you guys help?
I have the att version
jlczl
780
I pay $5/month to TMobile for the line. I add this additional line number to my GV number which is the number I give out to everyone as I've had it for a few years already.
Steve6371
9
I have a Galaxy s6 and am planning on getting a samsung gear s to pair with it. Do I need to buy a share contract through EE or just use my sim in my phone when not taking my phone with me
m1000
