Ok,
After reading the forms and after asking questions here (and experimenting) I finally figured this gear s out! Forgive me if you all knew this...but to me it was a process to figure out. For all my talk below...assume BT on and WIFI off.
I am on verizon: not sure if same on other carriers...but my mobile settings are
gear network ON/OFF/Auto (this is confusing...should be called GEAR PHONE RADIO
if OFF- disables mobile network (see below) and cannot recieve text on GEAR number OR Calls on Gear number
IF AUTO- on BT:can only use phones number for text/calls...but off BT can use gears phone number for calls/text
if ON- can always use gear phone for text/sms EVEN if on BT...(can use both at all times).....but see below...lose 10% battery per hour
Mobile network: check box for on or off ....should be called (mobile network)- it is what either connects you remotely if not withing bt range OR uses mobile network to stream/download if away from phone. when ON you can get text/alerts from phone even if phone left home (and on)
SO:
Today- had BT on paired to phone and had gear network auto (which means its OFF since was on BT)- 7 hours 20% battery with lot of use!!!!!!!!!!!
Today- had BT on paried to phone and had GEAR network ON (always was on BT)- lost 20% in 2 hours with light use
I recommend: keep gear network on auto (and mobile network checked).....if you step away from phone and dont need alerts...change gear net off. If you are ever somewhere where you MUST be reachable (2 methods): leave gear network ON always......but you will max get 9-10 hours on your fully charged gear.
hope this helps....sorry if was obvious to you all
SO:
