Notifications Wear Style for Gear S
This App emulates the behavior of Android Wear Watches when receive notifications.
It will send to your Gear S these notifications:
- Gmail
- WhatsApp
- Line
- SpotBros
- Viber
- Hangouts
- BBM
- WeChat
- Telegram
- Google Now
- Facebook Messenger
- Default email App
and the others you want.
First of all, enable this App to be able to listen to your notifications.
After that run the App on your gear S.
WARNING: It takes some seconds to connect first time. If doesn't work (The top-left button background is red) tap on red Button and press connect button or disable bluetooth in your mobile phone and enable it again.
- Swipe UP and Down for changing notification
- Swipe RIGHT to see more notifications pages
- Swipe LEFT to go to left but if it is the first page, the notification will be erased and in your mobile as well.
In some notifications you will see images like whatsapp if the notification image is shown in your mobile too.
In some notifications there are actions, you have to tap on it to execute it.
If the action has options to answer from the watch, the circle background will be Red instead of Blue and when you tap on it a list of answers will be showed.
Tap on any of them to answer the notification.
Now with keyboard included.
Now with voice input reply.
Now with options menu. Tap on top-left button to go.
Tested on WhatsApp, Hangouts and Gmail, but it should work in other Apps as well.
You select the Apps that you want to receive Notifications or not.
You can select the vibrations number for every selected App.
You can use this system and the default notification system as well. Select only the Instant Alerts checked in the default system and use this App for the rest notifications.
Go to the mobile App to select more settings.
You can enable or disable receiving notifications in the App settings or sending Broadcast intents from another App like llama or tasker.
You have to send these intents:
com.pacosal.gear.action.START
com.pacosal.gear.action.STOP
Now in spanish language as well.
This App is similar to this one http://forums.androidcentral.com/sa...430058-notifications-wear-style-gear-2-a.html but for Gear S instead of Gear 2.
It can be found on Samsung Gear Store.
- Gmail
- Line
- SpotBros
- Viber
- Hangouts
- BBM
- Telegram
- Google Now
- Default email App
