I hope this isn't impossible but so far I haven't found a way to make it happen. Is there a way to get notifications on the Gear S when it's not connected to my phone?
Thanks,
Deb
Thanks,
Deb
I believe that's what's installed. The clerk at the store did it and it did an automatic upgrade to the newest version for the gear. How would I know the difference?make sure you installed the gear app version, not phone version, using Gear Manager.
Jcybinski what To-do task/reminders app are you using?When Bluetooth is off or I'm away and the phone is still on my Gear S will connect remotely (via your Samsung account) and all my alerts forward fine. The calls also forward to my watch. I'm using a Galaxy S5 Active...
First none work, then some work, now back to none work. I need an app that works reliably when my phone is not connected to my Gear S but even when it is I still don't get them.
Have learned this is an issue suffered by others as well, wish Samsung would fix!
Deb from my Note 3
