Last night, I suddenly noticed that my S2 ring is loose. Just a little. No visible watch damage and I haven't dropped, banged, or otherwise caused something that would be huge. When you shake the watch, it has a slight rattle sound (as the ring is shifting back and forth against the metal of the watch).
It no longer feels 100% stable. It almost feels more sloppy. You can also see the ring movement. Maybe a millimeter or two.
Overall, very disappointing - but I am glad I am in the exchange window. For $300 this watch should be solid up to throwing it on the ground in attempt to smash it to pieces.
Maybe I'll try the Moto 360 v2.
