I noticed a new menu item "Connect to New Phone" and wondered if that meant it's now possible to change phones without having to go through the hassle of resetting the watch. Has anyone tried this yet?
J
J
If you use the S3 as a slave, then it can only have one master. It doesn't have enough processing power to have multiple masters. A reset is the best way to erase the old and prepare for the new. If you change phones frequently, you may want to consider using a dedicated companion rather than your phone.Everytime I get a new phone I have to do a lite reset. It's annoying, especially after going through 2 Note 7's and back to a s7 edge in a matter of a month..
Jimmy what two phones are you using now? I have an S7Edge through Tmobile and a Note 5 off Amazon -that's my primaryI noticed a new menu item "Connect to New Phone" and wondered if that meant it's now possible to change phones without having to go through the hassle of resetting the watch. Has anyone tried this yet?
J
