A
AC Question
Gear S2 suddenly won't hold a charge for even 8 hours. May be correlated to an upgrade of Samsung Gear that just occurred.
That sounds like the LTE radio is draining the battery. Are you in an area/building with poor reception where it's constantly searching for a signal?I've noticed that if the watches Bluetooth isn't connected to the phone, the battery will drain fast. Once I put the watch on airplane mode, the battery drain stops.
Actually, now you mentioned it, yes I am. The new building I work is horrible when it comes to LTE connection.That sounds like the LTE radio is draining the battery. Are you in an area/building with poor reception where it's constantly searching for a signal?
