Thank you Johnnyboy5. This is priceless information. What carrier is your LTE with btw?
K
I'm using LG V20 paired with the Gear S3. Quick question, I want to use Samsung Pay on the watch, but will I still be able to use Android Pay when I use the phone? Occasionally when I do not have my watch with me, I wish to still be able to make mobile payments. Anyone tried this before?
I'm a Google Voice user and all my calls and messages are routed through it. The watch phone number is listed as one of my call forwarding numbers and I use Hangouts for messages. Since buying the S3, I've stopped carrying a phone. The watch is remotely connected to an LG phone on my home WiFi, it never leaves the house, doesn't even have a SIM card. But this is required in order for notifications from non Tizen apps to be passed unto the watch.
Yes. Beyond initial app installation, the watch does not need to be connected to a phone to use S Pay. It only needs to be paired via BT occasionally (every 5-10 transactions) to replenish tokens, but otherwise will work in standalone mode. Remote connection, as you described, is needed for passing through notifications (i.e. Hangouts, email). Since all communication apps are setup on a dedicated phone and passed through to the watch, your primary phone is never paired with it.Will that work?
Yes, there is a Tizen messaging app. It's a yellow icon with a white dialog box (this is a different icon than when initiating a message from contacts). It's threaded by sender, once a thread is selected, tapping on the three dots gives options to reply, call, send location, block number, and delete.Is there supposed to be a stock messaging app on the watch? So I can select a thread and reply? Now I have to go to a specific contact to message that person. Running on a Asus Zenfone 3 Deluxe.
