I'm using a Galaxy S7 Edge with a Gear S3 Frontier (4G LTE, T-Mobile version). I recently updated my phone from Marshmallow to Nougat, and for reasons I can't remember I was asked to re-install my Gear Manager. This necessitated a light factory reset of my watch as well, so that I could re-pair the devices. Since then, my device has worked just fine with two notable exceptions: the weather app and S-Voice's ability to call or text my contacts.
When I try to perform the "add city" function in the stock weather widget, I get the usual note about giving the device permission to access my location. I then get a "finding location" dialog. However, it causes my phone to freeze up for a few seconds. I've tried going into the gear manager and accessing the settings for the weather app, and I get the same freezing behavior on my phone. It's as though any attempt to access my location on the phone weather app (except for using the phone desktop widget directly) fails.
Separate from this, when I try to text one of my contacts, I get a "contacts syncing" message, but my contacts never actually sync. I've read other messages on this forum in which people suggest connecting to wi-fi or LTE. I've tried this to no effect.
Before I ask for suggestions, here are things I've tried:
- Uninstalling the gear plugin and light resetting the phone
- Uninstalling the gear plugin and hard resetting the phone
- Force stopping the weather app via the gear manager
So far nothing works. Any ideas?
