1. clewcrew's Avatar
    I called Samsung's support and explained my bezel dial is now "loose". I can move it slightly left or right and the dial makes a tapping sound.
    Here is the kicker: the selection dial is NOT WARRANTED. I had to submit an exception along with a bunch of pictures to show there is NO PHYSICAL DAMAGE to the Samsung Gear S3 Frontier (which I bought from AT&T in January, 2017). I debated with the call screener and stated this was a core functional component of the S3 and why wouldn't it be under warranty? She did not have an answer.
    I have now submitted my claim exception to Samsung (by the way, my device is registered, but the serial number of the watch is not what they want - the IMEI number instead). I could not submit the claim online - had to make a call.
    I hope Samsung covers the watch. I have never dropped it. Even if I have bumped it or something else (as that is possible), are you kidding me that this product is so flimsy and Samsung knows it, hence the dial bezel not warranted (my "warranty" expires on March 2018).
    Great watch otherwise, but if Samsung doesn't warrant the watch, I will go on a personal Social Media campaign to provide reviews to help others avoid buying the S3 - and will sell mine. Too bad, it is the best looking watch on the market.
    03-20-2017 06:34 AM
  2. Hey_Yoh's Avatar
    I have the same problem on my S3 Frontier as well (never dropped it but dial becoming loose) and very curious of the outcome. Please give us an update....
    03-20-2017 10:39 AM
  3. Onthelookout's Avatar
    Clewcrew
    The only issue i have is with the bezel and the dire product knowledge and lack of consideration from everyone i've spoken to on this since getting thec1st watch in December. I'm nkw on watch 6 having returned everyone for replacement for the very same issue. The watch is awesone and why i keep it and try and try in vain hoping i can get this sorted. Samsung, incredibly seemed oblivious of there being an issue with a loosely fitting bezel which taps making the worst noise you'd want to hear from the most used part of the wstch. Fully with you to help others avoid buy this watch. Keep me posted.
    03-20-2017 07:44 PM
  4. dmits's Avatar
    The bezel is only pushed down around the screen and held there with a rubber seal. There are 4 little balls on springs that keep it up floating off the watch body so it should actually move left and right and up and down.
    Today 07:13 AM
  1. Text entry in S Note on a Galaxy Note 5
    By johnmurf in forum Samsung Galaxy Note 5
    Last Post: Yesterday, 06:06 AM
  2. Why does my screen stay on during calls?
    Last Post: 03-20-2017, 06:32 AM
  3. The power button and the volume up button acting weird..
    Last Post: 03-20-2017, 06:25 AM
  4. specific colour to a specific contact on my edge peope,
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 03-20-2017, 05:50 AM
  5. specific colour to a specific contact on my edge peope,
