1. bmoore0909's Avatar
    I dont know about you guys, but a major gripe I have with the S3 Classic is getting the face to turn on when I look at it. Sometimes I have to turn my wrist twice to get it on.
    So I tried to AOD and I guess it "works" but it's really hard to see. it's so dim it's almost worthless...not worth the battery drain.
    Is there a way to adjust the brightness of AOD?
    Thanks
    04-12-2017 10:45 AM
  2. Darth Mo's Avatar
    I don't think you can adjust the brightness of the dimmed AOD independent of the active display.
    But you can get the app Watchmaker Premium which makes it easy to install thousands of watch faces. Many of those offer much better options for AOD, from a minimal dim and full detail of the full watch face, to high contrast ones that leave tick marks and hands bright but dim the rest of the display to conserve battery.
    04-13-2017 01:18 PM
  3. jackal24's Avatar
    And you can also change the settings of pretty much any watchface in that app, so if the aod is too Dim, you can turn it up, etc.
    04-21-2017 08:29 AM
  1. Replays song on mute then continues??
    Last Post: 04-15-2017, 03:01 PM
  2. Replies: 1
    Last Post: 04-12-2017, 05:31 PM
  3. My Lenovo Tab2 A8-50f is frozen on Lenovo Logo
    Last Post: 04-12-2017, 05:21 PM
  4. Replies: 1
    Last Post: 04-12-2017, 02:03 PM
  5. Hyperion extended battery case finally available on Amazon
    By Mike Dee in forum LG V20 Cases & Accessories
    Last Post: 04-12-2017, 10:27 AM
