dst problems
aeiou
20
so ever since the dst change on sunday my intercept has been acting strange. At first on sunday it was fine. Time was updated first thing in the morning like normal. Now, it thinks it's an hour earlier. The only place it shows the right time is in the clock app. in the notification bar and lock screen it's an hour behind. If I reboot the phone, the time is right until it finds the network and then its off again. My wife's blackberry on the same network has the right time.
shmutt1980
60
4
Hmm... mine are all fine, maybe its one of your apps thats messing with it. Check for updates on your apps, esp the ones that use time functions (alarm clocks, messaging, etc). then try uninstalling them if there arent any, see if that corrects it.
aeiou
20
Good idea, idk if I have any tho.
Apparently it thinks that it's in mountain time, even tho I'm in central. I can set it to manual and put it back to central time and its right, but as soon as it's set back to network time it thinks its mountain time.
