Is there an app for the moment that shows the battery life left? My wifes palm shows her battery life left when she opens it. I would like some sort of meter that provides similair info...
yea i got the battery indicator by darshan computing on the market its pretty good and free its tells u the percentage on the status bar and when u touch it it tells u the temp. and voltage. there are many on the market but i like this one the best.
i like the one from mippin "battery widget" better it's a widget with the % on it when you click it it lets you turn off/on your wifi,...gps,...and also takes you straight to settings. it's not a full running program like the others that kill your battery!!!theres turn on a program when you click to check them. use your app killer to check which ones are allways running.
