So yesterday I was playing some music on my phone out loud while I was finishing up some homework. At first, it was saying that my battery wasn't charged enough to play the songs. But, I looked at my battery life and it was nearly perfect. So I just charged it up anyways because my phone has also been having some trouble with the battery (( it thinks it's charging and will keep beeping/vibrating every two seconds even though it's clearly not plugged in so then I'll turn my phone off and back on and it will say that my battery is like 5% full even though it was over 70% before I turned it off)). But anyways, I plugged it up to my charger and it started playing the music when I pushed the play button. But the red light that's usually on when it's charging wasn't on. So then I unplugged it while the music was playing and after the song was done it wouldn't play the next song because it had a "low battery". So I thought that maybe my phone wasn't showing me the correct battery life, like it sometimes does. So I powered my phone off and tried to power it back on when it was off, but nothing happed. I tried plugging it in while turning it back on; I tried pushing all types of combos of buttons (volume down and power) so don't tell me to do that cause it won't work. I've tried taking the battery and sd card out; I've looked through more forums and pages on google than I can handle. If I go to the sprint store to getting fixed, I think I'll be pretty much done with sprint because they ALWAYS MESS STUFF UP!!!!
Please help me!! I neeeed my phone no matter how stupid it is because it's my only one until next year!:-\
PS: I have a Samsung Replenish-__-
