so i root my phone, and while i'm browsing for apps that give the advantage of rooting, i come across adaway. it worked well, and it really did get rid of all ^#%@$%@$% ads. but now, after i flashed phonix 0.2 [sorry, i'm a bad speller] deodexed, all !@@#$ broke loose. after i flashed, i redownloaded all my apps [including adaway] signed into google play, and then gave myself a pat on the back for flashing my first rom. but when i tried to apply adaway, it shows, symlink missing or incorrect. symlink is missing from your target to /system/etc/hosts is not existing or incorrect! adaway will not work if it is not pointing to the right file. do you want to try creating a symlink? and i hit yes and it says symlink creation failed. a solution is to boot your phone into recovery and create a symlink there with 'in s- /data/data/hosts /system/etc/hosts.' now i understand what a symlink is [not really, i'm looking it up after i post this] and thats a command, but how do you @@##$#!!@##$?@ use the command in cwm 5 @!##!$!@#!%$!##$%$%^%^@^$%%@??!$#??????????????/????
