So in the 2-3 weeks I've had my Stratosphere, I've encountered two situations in which the extended battery didn't want to charge. I got the extended battery two days after I bought the phone and with my usage and how thicker and better-feeling the phone is with it, I have no desire to go back to the regular battery.
Before I begin, I've used both the stock charger and my Motorola bluetooth headset charger to charge my phone and for the most part haven't had any issues whatsoever. When I charge it I'm usually not using it at the same time so it's simply charging plus whatever background activities it may be running, which are minimal. Also, my OS is the stock OS that came with the phone.
One time, the battery was low, so I used the charger that came with it and plugged it into the wall. The battery showed the lightning bolt to indicate it was charging, but it simply did not charge. Even when the "100 percent" icon popped up, I unplugged it and it was as if it had never charged. I plugged it in to my other charger for my Motorola bluetooth headset, went to bed, all was fine the next morning.
This morning, the battery had ran down to nearly nothing. I plugged it into my Motorola bluetooth headset charger. I woke up, the "100 percent" icon popped up, and it was the same issue again when I unplugged it: the phone had no juice as if it never charged. I plugged it back in, waited a while (15-20 min or so), no dice. The battery status field in the setting said it was low on power and needed to be charged -- which I was doing.
So, I powered the phone completely down and left it off for a couple of minutes. Then I plugged it into the charger again, then I turned it on. Now it appears to be charging. The battery status field was at 16 percent and then 18 percent when I checked a couple of moments later. The battery icon charging animation went from the orange empty battery to a full blue at first, and now is partially-filled blue to full blue, which shows the progression that it is charging.
Now, when you create a thread on this message board, it will pop up possible duplicate threads based on what your title is. I came across this one.
http://forums.androidcentral.com/dr...ttery-issue-says-charging-but-really-not.html
I'll be honest, given that this is a spot occurrence, I don't think it is the strength of the chargers in question, especially since it has happened with two chargers. Since I didn't think to look at what apps were running, however, I cannot rule out those possibilities of apps consuming power -- yet e-mail, basic phone usage, and hourly updaters like Facebook and the Accuweather widget are pretty much it, and those do not consume much it appears.
I guess I am not sure what more to add here to describe my problem. I tried to be as thorough as I could be, but in the event I missed something I will gladly add it the next time I see this thread. But the bottom line is I want to know what is causing the issue so I know if it is a software bug, if it is an issue necessitating a return to the VZW store, or another option that needs considered. (I wouldn't think it would be the battery, because this problem is rare; I'd think a battery issue would mean it would never hold a charge.)
Apologies for my long-windedness. Thanks in advance for any help you can provide.
