Results 1 to 5 of 5
    Default Annoying screen lock after calls
    Anyone know of any way to prevent the screen from locking after EVERY call?
    Doesn't matter if call was 10 seconds or 1hr...the screen always locks after disconnecting a call.
    Also...how to keep screen from timing out during calls?
    Any help would be greatly appreciated.
    R
  2. #2
    Default Re: Annoying screen lock after calls
    It was annoying to me, also the quick reply with handcent was making it lock after I typed a reply.
    One thing you can do is disable the lock screen completely with the app "No Lock"
    Thanks joepits!
    While not optimal, the combination of the No Lock and the GO Launcher apps is good enough for now. Hopefully a software update will soon fix this silliness.
  4. #4
    Default
    Can you guys describe this in detail? Don't think I'm seeing this.
    Sent from my SCH-I405 using Tapatalk
    Not much more to describe than above...
    Does your phone lock the screen after you disconnect calls and timeout the screen within a few seconds after placing a call?
    Note: If you don't use any lock at all, you won't see it.
