Results 1 to 2 of 2
    Shawheim's Avatar
    Posts
    Global Posts
    217 Global Posts
    ROM
    CM9
    Default picture problems
    so my girlfriend is having problems when she is taking pictures. when the picture goes to save it always messes up unless she uploads it right away. she got the corrupted sd card notification so the card was reformatted. still having the same issue. just was wondering if anyone else was having this issue or if you think she just needs a new sd card. thanks!
  2. #2
    chase2hoop's Avatar
    Posts
    ROM
    CM7 (Nook Color only)
    Default
    I had this problem with the included SD card. I just got a new one and it worked.
    Sent from my SCH-I405 using Android Central Forums
