Results 1 to 2 of 2
    jakblack's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help!
    Hello I order a replacement phone months back. When I did I setup up the phone as told and everything work..but! It won't read my sd card. This is bout the four months going with this prob can anyone help me out with this
  2. #2
    acejavelin's Avatar
    Posts
    Global Posts
    1,745 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help!
    So you moved your SD card (NOT the SIM card) from your old phone into the new one, and it is not seeing it?
    Go to Settings - Storage and see if it's in there, if not, try to mount it. Does it work if you take the microSD card and put it in a card reader or another device?
