New Stratosphere Mass Storage Not Working After Total Phone Replacement (and other issues)
dropped my old strat, cracked the screen up. ordered new phone through verizon. it came very fast.
1st thing i did was wall charge it without turning it on.
then i turned it on, set it up, and installed spotify, because that is my main phone use
but spotify wouldn't start. it just gave me a blank screen. i found .
but in order to do that, i figured i would have to mount my sd card to my computer (a mac in this case since i'm at work)
to my surprise, no matter what i tried, i could not get the sd card to show up on the computer as a drive. the verizon mobile cd thing shows up, but no mounted disk (called "no name" before)
i tried turning on usb debugging and rebooting as one forum said. no effect. "ask on connection" on and off.
Re: New Stratosphere Mass Storage Not Working After Total Phone Replacement (and other issues)
Every now and then, when rebooting, the sd card is not recognized. Usually rebooting again solves it.
thanks for the reply.
i have rebooted several times. the sd card is recognized by the phone for internal storage.
the problem comes when trying to set the phone to become a mass storage device for computers. the "connect starage to pc" window never comes up and so on.
this is a brand new phone from verizon, but would it be worth it to do a factory restore anyway?
Portions of this page are modifications based on work created and shared by the Android Open Source Project
and used according to terms described in the Creative Commons 2.5 Attribution License. AndroidCentral is an independent site
that is not affiliated with or endorsed by Google.
