DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By OptimusI
    OptimusI's Avatar
    Posts
    Global Posts
    54 Global Posts
    Default Stratosphere Nandroid Help
    I recently discovered, much to my irritation, that my Strat consistently fails a nandroid backup. When using CWM, it produces no md5 and the data.rfs file ends up as a 0kb file. I tried Onandroid, but that gets as far as SDcard found and then stops and hangs. Additionally, the TI backups I made break wifi and the home button when restored. So now that I've manually rebuilt from scratch once, I'd love either another method to do a nandroid or some help getting the above methods to work. In case it's probative I'm running dwitherell's tweakstock and one of the tweaked kernels though I'll have to look up which one. Any help is appreciated!
  2. #2
    acejavelin's Avatar
    Posts
    ROM
    Stock OTA and Global RUU
    Default Re: Stratosphere Nandroid Help
    I always used CWM Recovery to make Nandroids, it worked fine... although many people get the backup done and then when they try to restore the MD5 fails, I never had that issue.
    Are you sure you have enough free space on your SD card?
    Current Android Phones: HTC Rezound x2 (Stock ICS 4.5.605.14 Official OTA update, for now anyway)
    Current Android Tablet: Nextbook 8 Premium with marxo's N8+ ROM - Revision 1b2 (ICS 4.0.4)
    Previous Android Devices: HTC Droid Incredible 2, Samsung Stratosphere
    OptimusI's Avatar
    Posts
    Global Posts
    54 Global Posts
    It's happened with two different cards. How much free space does it need? I have a 4 gig I will wipe and try.
    OptimusI's Avatar
    Posts
    Global Posts
    54 Global Posts
    That was it! Well I feel foolish. Still a little annoying that CWM just aborts and reboots instead of popping an error. Not that I'm in any position to complain since I wouldn't even know where to begin to code something like CWM and it is free and awesome.
    acejavelin likes this.
  1. New Stratosphere User - Help!
    By neecer1202 in forum Introductions
    Last Post: 01-05-2012, 06:08 AM
  2. Nandroid help
    By mrsethprice in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-22-2011, 08:21 PM
  3. HELP!! Lost SD card and all nandroid backups, now stuck in boot loop
    By handbra#ac in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 09-22-2010, 09:24 AM
  4. nandroid help
    By flomexico in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-14-2010, 01:40 AM
  5. S.O.S:nandroid backup help!!
    By big_mofo in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-10-2010, 07:51 AM
