Page 2 of 9 FirstFirst 12345 ... LastLast
Results 26 to 50 of 219
Like Tree17Likes
  1. Thread Author  Thread Author    #26
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MegaTron 6.0.4 / Bobzhome
    Default Re: [Guide] How To Root Samsung Transform Ultra
    I see you in IRCNode. Goto bottom of the little screen and type.
  2. #27
    Celsey N Pereira's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Took me a while but with some help I got it done. It works (: Thank you for the help!
    DroidXcon and niteNarmor like this.
  3. Thread Author  Thread Author    #28
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Not a problem. Always here to help!!!!
  4. #29
    dilbert#WN's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What do I do if it never completes the Odin download? It starts, on the phone the last few lines are wait for usb_read, COMMAND_SET_READY_SIZE, ODIN Downloader, Image download START, Image size : 6291456
    On the PC the first box says RECOVERY the green bar is half of the box below and the time is counting up, in the Message window the last few lines are <1> START!!!, <1> set download environment., <1> recovery.img download..
    The first time I let it run for almost 40 minutes the second 10 minutes and still doesn't finish. I tried win7 x64 but Odin crashes, I am currently using XP x86
  5. Thread Author  Thread Author    #30
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    You didn't follow instructions.please look at the op again.
    8. Press start.
    IMPORTANT!!!!!! Once the phone goes to black screen, unplug the usb cord from phone!!!!!!
    Put battery back in and go into recovery. If you miss this step then you will have to start all over again.
    To get to recovery:
    1: Press and hold the volume down button
    2: Press and hold the power button
    3: Once the Samsung logo appears, let go of the power button.
    Scroll down to "install zip from sdcard" - press power button
    5 options will appear on next screen choose the first "choose zip from sdcard" press power button
    Scroll till you find tu_root.zip and press power button
    Scroll down to "Yes - Install tu_root.zip" press power
    Let it finish.
    The whole program takes about 10 seconds or less to complete.
  6. #31
    lefteye3da's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    on the odin, it doesn't show he yellow bar or the message on the borrom.
  7. Thread Author  Thread Author    #32
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Your phone needs to be connected to computer for triangle to show. Or are you talking about Odin on phone?
  8. #33
    lefteye3da's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    im talking when I set the phone on download mode and try to connect to odin mutli downloader.
  9. Thread Author  Thread Author    #34
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by lefteye3da View Post
    Please be sure you have the latest drivers available. Once you connect phone to computer (and your phone is in Odin) you should see the yellow box appear in the Odin program on the computer.
  10. #35
    Funplayz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i open odin but tranform ops is not seen by it
  11. Thread Author  Thread Author    #36
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Need the latest Samsung drivers. Go to Samsung website to get them. When you connect phone to computer does the computer recognize phone? Is your phone in download mode?
  12. #37
    Funplayz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i try to put it in download mode but goes to reboot,recover,zip from from sd
  13. Thread Author  Thread Author    #38
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by Funplayz View Post
    do me a favor.... go to IRCNode - use your username here and tab done to connect and type in transform-ultra. It will enable us to talk in real time. IRCNode
  14. #39
    Funplayz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    im on ircnode
  15. Thread Author  Thread Author    #40
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I don't see you?!?
  16. Thread Author  Thread Author    #41
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Follow this link ----> irondust
  17. #42
    Funplayz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    for channel put tranform-ultra
  18. Thread Author  Thread Author    #43
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Correct
  19. #44
    ManFukkk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I followed as well & nothing. Could it be my usb cord? my phone is Samsung transform ultra but cord is for blackberry. My guess the cord has nothing to do with it
    Quote Originally Posted by niteNarmor View Post
    Two ways to check if rooted. #1 do you have the super user app? #2 go into recovery mode ( power off... then press and hold volume down and power button) tell me how many options do you have.
    Not trying to sound mean or anything but if you followed to the "t" then you are rooted.
    This method has been tested by hundreds of members. This method is tried and true. Like I stated in post #1, 99.9% of issues , are because a part or whole of instructions where NOT followed.
  20. Thread Author  Thread Author    #45
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by ManFukkk View Post
    No your cord is fine. My guess is you don't see the superuser app? I have seen a couple of instances where thus has happened. Please let me know.
    Sent from my SPH-D700 using Tapatalk 2
  21. Thread Author  Thread Author    #46
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Also let me know how many options you see if when your in recovery...
  22. #47
    rotcod1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    when I browse for the select OPS file in Odin, I don't see the .ops file on my desktop where I downloaded it to. It's in the dropdown (showing the file pathway) but it's not visible to in the window to possibly click on. When I highlight it in the dropdown, it will appear, it seems to appear in the "OPS window" in Odin, but upon hitting start (after doing the selet integrate bit), an error pops up, it says ...Ultra.ops was not found.
    Well, I downloaded it again to dropbox and moved it from there to my desktop. It seemed to work. Now if I can just figure out if I'm root.
  23. Thread Author  Thread Author    #48
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What is the file extension on the downloaded file? It does need to say .ops for Odin to see it properly.
  24. #49
    rotcod1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, I downloaded it again to dropbox and moved it from there to my desktop. I could see it that time. It seemed to work. Now if I can just figure out if I'm root.
  25. Thread Author  Thread Author    #50
    niteNarmor's Avatar
    Posts
    Global Posts
    160 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Lol... you need to look in the apps and see if you have superuser.. it has been my experience, some users did not receive that during flashing. Plus if you followed the instruction, go back to recovery. There you will have more options (10 total) if you are rooted.
  1. [GUIDE] How to Root Your Nook Color
    By Will Shanklin in forum Barnes & Noble Nook Color
    Last Post: 03-27-2014, 04:52 PM
  2. [Sticky?] Newb guide -- How to root, recovery, and ROMs [Windows]
    By t0ast3d in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-10-2014, 02:33 PM
  3. [GUIDE] How to root, un-root and rom your Droid Incredible.
    By Brett in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 12-22-2013, 07:37 PM
  4. [GUIDE] How to Root the Samsung Galaxy Tab 10.1 [Video Walkthroug
    By R3Z in forum Samsung Galaxy Tab 10-inch
    Last Post: 09-09-2011, 03:48 PM
  5. Video Guide: How to Root the Samsung Moment, Add WiFi tether, (hotspot), and themes.
    By IOWA in forum Samsung Moment Rooting, ROMs, and Hacks
    Last Post: 08-02-2010, 03:22 PM
