- 01-23-2013, 11:57 PM
Thread Author #1
- 01-24-2013, 05:15 PM
Thread Author #2
Re: [Guide] How To Root Samsung Transform Ultra
Reserved
All thanks for the above banner goes to TexasEpic4G
- 01-27-2013, 12:39 PM #3
- 01-27-2013, 12:40 PM
Thread Author #4
- 01-27-2013, 12:44 PM #5
- 01-27-2013, 12:45 PM
Thread Author #6
- 01-27-2013, 12:47 PM #7
- 02-03-2013, 07:13 PM #8
- 02-03-2013, 08:16 PM
Thread Author #9
- 02-10-2013, 11:23 PM #10
- 02-11-2013, 06:17 AM
Thread Author #11
Two ways to check if rooted. #1 do you have the super user app? #2 go into recovery mode ( power off... then press and hold volume down and power button) tell me how many options do you have.
Not trying to sound mean or anything but if you followed to the "t" then you are rooted.
This method has been tested by hundreds of members. This method is tried and true. Like I stated in post #1, 99.9% of issues , are because a part or whole of instructions where NOT followed.Last edited by niteNarmor; 02-11-2013 at 09:07 PM.
- 02-12-2013, 11:50 AM #12
- 02-12-2013, 12:12 PM
Thread Author #13
- 02-12-2013, 06:46 PM #14
- 02-12-2013, 06:59 PM #15Thanked by:
- 02-12-2013, 08:27 PM
Thread Author #16
As what above poster stated. When downloading DO NOT OPEN THESE FILES. They won't open with windows and there is no need. Hit save then follow op's instructions.
- 02-14-2013, 08:33 PM #17
- 02-14-2013, 08:42 PM
Thread Author #18
Where are you downloading the files to phone or computer?
The following is for computer.
Just copy the file to your sdcard where all your files at.
1. Plug phone to computer.
There will be three choices to chose from.
More instructions to follow. Please stay posted.
2. Choose USB - copy files from USB.
3. Select yes.
Next you should see the android character show up on phone.
Also, (if using windows) a pop up should show up on computer.
Open pop up on computer.
Open download file and find tu_root.zip.
Click and drag that zip from your computer to your sdcard.
It is now on the root of sdcard.All thanks for the above banner goes to TexasEpic4G
- 02-14-2013, 08:57 PM #19
- 02-14-2013, 09:02 PM #20
- 02-14-2013, 09:13 PM
Thread Author #21
- 02-14-2013, 09:14 PM #22
Sorry I keep bothering. When I click on "OPS" and you tell me to find the TransformUltra thing I downloaded, I can't find it anywhere. Where do I look? It's not showing up unless I look for it by clicking on my document through the start menu.
- 02-14-2013, 09:17 PM #23Thanked by:
Thread Author #24
you NOT bothering me. This is why I am here... Please go to the link I gave in above post....
- 02-14-2013, 09:17 PM #25
[GUIDE] How to Root Your Nook Color
By Will Shanklin in forum Barnes & Noble Nook ColorReplies: 224Last Post: 03-15-2013, 03:16 PM -
[GUIDE] How to root, un-root and rom your Droid Incredible.
By Brett in forum Incredible Rooting, ROMs, and HacksReplies: 244Last Post: 02-12-2013, 11:52 PM -
[GUIDE] How to Root the Samsung Galaxy Tab 10.1 [Video Walkthroug
By djR3Z in forum Samsung Galaxy Tab 10-inchReplies: 3Last Post: 09-09-2011, 02:48 PM -
Video Guide: How to Root the Samsung Moment, Add WiFi tether, (hotspot), and themes.
By IOWA in forum Samsung Moment Rooting, ROMs, and HacksReplies: 1Last Post: 08-02-2010, 02:22 PM -
[Sticky?] Newb guide -- How to root, recovery, and ROMs [Windows]
By t0ast3d in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 1Last Post: 06-20-2010, 01:19 AM
Reply
