1. dorelse's Avatar
    I've had to switch to Opera and/or IE as the AC site no longer fully loads in Chrome...it just hangs up, can't scroll up or down, and the hyperlinks that I can click on, don't match the picture. For example, if I click on the 'Forums' link, the Nexus 4 & Nexus 10 review article is pulled up.
    Started yesterday.
    11-14-2012 10:57 AM
  2. Devinator's Avatar
    Are you experiencing this on multiple devices/PCs?
    11-15-2012 10:24 AM
  3. gone down south's Avatar
    None of those problems, but I can't use the back arrow in Chrome, it just keeps going back to the same page I'm on.
    11-15-2012 11:17 AM
  4. Devinator's Avatar
    So you have only experienced the issue on one device/PC, but, on others it's fine? If so, maybe reinstall Chrome?
    Sent from my Transformer Prime TF201 using Android Central Forums
    11-15-2012 11:18 AM
  1. Does anyone else have problems with a negative email count.
    By thatguitarguy in forum Sprint Epic 4G
    Last Post: 01-26-2015, 02:48 PM
  2. Anyone else having problems with the HTC clock/weather widget?
    By zrxoa1 in forum Verizon Droid Incredible
    Last Post: 04-19-2011, 09:48 PM
  3. Replies: 16
    Last Post: 04-01-2011, 09:34 AM
  4. Replies: 1
    Last Post: 01-22-2011, 08:39 AM
  5. is anyone else having problems with pdanet?
    By SchizoSlimm in forum Android Apps
    Last Post: 11-18-2009, 10:28 AM
