1. Loui Lebeco's Avatar
    My z1 compact is just a month old and this is my first smartphone to have. Is it normal for my phone to last less than a day with my mobile data being used alot and playing game(samurai siege specifically) too? I have to charge it everyday. It seems the battery life that others enjoyed from the reviews I read is different from what I got. Replies will be a great help for me Sirs/Ma'am s. Thank you!
    08-07-2014 11:41 PM
  2. B. Diddy's Avatar
    Battery life depends on a lot of factors. Some of the most important factors include total screen-on time (which averages around 4-5 hours for the typical battery), CPU usage (especially by complex games), and poor cell signal (which makes the phone's radios work harder to get a signal).
    It would help to see screenshots of your battery stats. Show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (showing total Awake time and Cell Signal Strength.
    3. The Screen category, showing total Screen On time.
    4. The Cell Standby category (if present), showing Time without Signal.
    Here's a guide on posting screenshots: http://forums.androidcentral.com/amb...d-central.html
    Loui Lebeco likes this.
    08-08-2014 01:01 AM
  3. naullsy1985's Avatar
    I use my z1 compact moderately throughout the day. Checking social media apps a few times a day, watching a few you tube videos, browsing the Web, maybe half a dozen calls and messages, checking emails twice a day and I usually end up with about 65% by the time I go to sleep. I usually get 15 hours and only use up about 35%.
    I have stamina mode on all day, vibrate off, I've disabled all stock apps I don't use, and auto sync turned off. I find keeping location turned on is a killer. So I keep that off and just turn it on when I use Google maps.
    But like the fella said above the best way for someone to help is to take some screenshots and at least then someone can get more of an idea of what's going on. Hope this helped
    08-08-2014 01:33 AM
  4. Loui Lebeco's Avatar
    Can't do my screen shot. Can't find this thread even though I downloaded the app.
    08-08-2014 01:55 AM
  5. Loui Lebeco's Avatar
    My estimated battery time for a 52% battery is only 14 hours while its standby mode is 2 days and 9hours.
    08-08-2014 01:58 AM
  6. Loui Lebeco's Avatar
    Finally.
    Attached Thumbnails Z1 compact battery issues-6997.jpg   Z1 compact battery issues-6998.jpg
    08-08-2014 02:01 AM
  7. B. Diddy's Avatar
    Ok, that's a start. But wait until you've charged up to 100%, then discharged down to 20-30% after normal usage (without recharging in between), and then post the screenshots I suggested above.
    Specifically, to get the fullscreen battery graph, tap the smaller graph in your second screenshot.
    Tap the Screen category and Cell Standby category to get the details I mentioned before.
    08-08-2014 02:16 AM
  8. Loui Lebeco's Avatar
    Is this right Sir?
    08-08-2014 10:02 AM
  9. Loui Lebeco's Avatar
    08-08-2014 10:03 AM
  10. B. Diddy's Avatar
    No, those screenshots are at 100% charge. Wait until the battery has gone down to 20-30% with regular usage, without recharging at any time. Then show us the screenshots.
    08-08-2014 11:10 AM
  11. Loui Lebeco's Avatar
    How about this sir, I forgot to monitor. Sorry.
    08-08-2014 11:12 PM
  12. Loui Lebeco's Avatar
    08-08-2014 11:13 PM
  13. B. Diddy's Avatar
    Ok, that's more helpful. But we still need to see the main Settings>Battery screen to see the breakdown of % battery usage by app/service, as well as the individual Screen and Cell Standby categories.
    08-09-2014 12:41 AM
  14. Loui Lebeco's Avatar
    08-09-2014 12:51 AM
  15. Loui Lebeco's Avatar
    08-09-2014 12:52 AM
  16. B. Diddy's Avatar
    Good. Now tap on Screen and Cell Standby, and show us those screenshots.
    08-09-2014 01:02 AM
  17. Loui Lebeco's Avatar
    And my phone at 100% only said that it will last for only a day unlike before it was 2 days or more.
    I'll just post tomorrow another screenshot of my phone readings with 20% battery remaining.
    Thank you for your responses Sir!
    08-09-2014 07:55 AM
  18. Loui Lebeco's Avatar
    This one Sir.
    08-11-2014 12:51 AM
  19. Loui Lebeco's Avatar
    08-11-2014 12:52 AM
  20. Loui Lebeco's Avatar
    08-11-2014 12:52 AM
  21. Loui Lebeco's Avatar
    08-11-2014 12:52 AM
  22. B. Diddy's Avatar
    Ok, so you're showing 4.5 hrs of screen-on time, with 20% battery still remaining. So if we were to extrapolate the total screen on time with 0% battery left, it would be a little over 5.5 hrs. That's pretty good for screen-on time. It sounds like your phone is acting pretty normal.
    08-11-2014 02:37 AM
  23. Loui Lebeco's Avatar
    Really Sir? Thank you!
    08-11-2014 09:45 PM
  24. joe229's Avatar
    Sir, does screen on time of around 5 to 5.5 hours with screen at minimum brightness all the time indicate that the battery is normal?. I just bought a new Z1C a week back and it was manufactured and imported in september 2014, and now its nearly a year, so could that have affected the phones battery?. I get around 5 hours of screen on time but always at minimum brightness with mainly browsing in chrome, whatsapp, gmail and listening to music on the walkman app. And many people say they get 2 days out of the phone with my kind of usage with a screen on time of around 6 to 7 hours. But i have to be very careful with my usage to get a day itself. I keep the phone on 2g only 90% of the time since i rarely use mobile data. P.S.: When simply browsing on wifi 1% decreases every 3-5 mins.
    07-06-2015 10:39 AM
  25. lgibm's Avatar
    battery lasts only three days
    08-05-2015 05:21 AM
  1. 2 issues with phone calls
    By blkraptor in forum Ask a Question
    Last Post: 09-08-2014, 02:39 AM
  2. Galaxy Exhibit 4G Charging Issue
    By yy1234 in forum Ask a Question
    Last Post: 08-16-2014, 02:57 PM
  3. GT-N5100 Issues with S Pen
    By InANutshell7809 in forum Samsung Galaxy Note 8.0
    Last Post: 08-15-2014, 03:09 PM
  4. Why removing battery solved problem?
    By budgy in forum AT&T Galaxy S III
    Last Post: 08-11-2014, 06:16 PM
  5. Nexus 5 KitKat 4.4.4 WiFi Issue
    By silentbobdrummer in forum Google Nexus 5
    Last Post: 08-09-2014, 09:03 AM
