Results 1 to 7 of 7
    JDB37's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Changing sound profiles
    Hi - just bought a Z1 - my first android phone. I'm trying to customize the sound profile so that I can hear phone calls and texts at night, but I'm not bothered by e-mail alerts. On my old Blackberry this was easy, but the Z1 just appears to have three settings - sound alerts, vibrate alerts or silent. I suppose I can go into the e-mail settings every night and switch off the notifications, but this seems a very long-winded way of doing it. Is there a menu (or an App) that allows me to specify a personal sound profile?
    Thanks for your help
  2. #2
    Rule9's Avatar
    Banned
    Posts
    Global Posts
    871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Changing sound profiles
    Quote Originally Posted by JDB37 View Post
    Or you could simply pull down the quick settings from the top notification panel and turn off auto-sync before bed. That should stop automatic email checks.
    JDB37 likes this.
  3. #3
    Ghostline's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would suggest to use Smart connect feature, so if you plug the phone for charging at night one of the action will be switching email notifications off.
    Anyway, this works for me.
    JDB37 likes this.
    JDB37's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been switching off autosynch at night, which has worked but I like the sound of this app. Will definitely try it. Thanks aga
  5. #5
    deer_dodger's Avatar
    Posts
    Global Posts
    26 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Really interested in your thoughts on the phone. I'm looking at the Z1 at the moment but a wee bit concerned by the criticism about poor viewing angles on the screen.
    JDB37's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm very pleased with it. I'm not exactly a power user - I mainly use it for calls texts and e-mails + some photographs and it's perfect for this. I like the large screen as my fingers are not very adept at using a touch screen on smaller phones. Also it has excellent battery life - I generally only have to charge it once every two days, which is substantially better than my partner's i-phone. I've never noticed any problems with the viewing angle - certainly for normal use it's absolutely fine. I don't usually use it to watch video but the few times I have there have been no problems.. I would certainly recommend it.
  7. #7
    Posts
    Global Posts
    26 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Perfect thanks, I really appreciate your real world thoughts.
  1. My Samsung Galaxy S3 Mini won't let me change my lock screen!
    By sophia_alv in forum Samsung Galaxy S3 Mini
    Last Post: 09-04-2015, 03:30 PM
  2. Replies: 4
    Last Post: 01-02-2014, 10:09 AM
  3. Samsung Galaxy Note 2 - Are there s-note and s-pen changes on 4.3
    By gdanonym in forum Samsung Galaxy Note 2
    Last Post: 12-11-2013, 11:29 AM
  4. AC app profile picture problem
    By sentinelred in forum General News & Discussion
    Last Post: 12-06-2013, 08:26 PM
  5. notification sounds 2x
    By Jeric Gorospe in forum Samsung Galaxy Note 3
    Last Post: 12-04-2013, 03:54 AM
