Results 1 to 4 of 4
    lorcar's Avatar
    Posts
    Global Posts
    8 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help customize lock screen: weather + alarm + clock
    Hi everyone
    i haev z1 compact.
    I'd like to customize a bit my lock screen, so to show current time, current weather (and maybe next few days as well), alarm in ONE page.
    I tried few popular extensions, but it was not in ONE page.
    I also downloaded Transparent Weather, but it has TWO problems:
    1- I cannot resize it properly! i widen the widget as much as needed, but every time it shrinks back!
    2- it doesnt show the alarm
    any help?
    thanks in advance
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: help customize lock screen: weather + alarm + clock
    Dashclock can be added to your lock screen. Shows the clock mainly, and to the side are smaller but clickable tags, with the necessary add ons, like the weather, battery, and alarm.
    The weather cannot display a forecast, but clicking on the weather, will take you to either the predetermined weather application, or, I have 1Weather, and that has a supported dashclock extension. One click and I am in my weather application.
    lorcar's Avatar
    Posts
    Global Posts
    8 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks
    is there a reason I cant keep the lock screen widget the dimension i want? it gets shrinked back every time
    also, why cant I put more than one widget in each lock screen pane?
  4. #4
    jendrke's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lorcar View Post
    thanks
    got the same problem on my z3c, just looks like a clock, with a small icons, of weather and gmail.
    I installed more features, but like you i can't see them on lockscreen
  1. LG G3 Power/lock button is loose. Can it be repaired?
    By senorsugar in forum Ask a Question
    Last Post: 04-24-2016, 05:18 PM
  2. Help with Tab S Purchase
    By dminches in forum Samsung Galaxy Tab S 10.5
    Last Post: 08-26-2014, 12:45 PM
  3. Screen turns on when I unplug phone
    By Thatlankyguy03 in forum Ask a Question
    Last Post: 08-26-2014, 10:40 AM
  4. LG G3 Power/lock button is loose. Can it be repaired?
    By senorsugar in forum Introductions
    Last Post: 08-26-2014, 10:21 AM
  5. LG G3 Power/lock button is loose. Can it be repaired?
    By senorsugar in forum General Help and How To
    Last Post: 08-26-2014, 08:36 AM
