1. asdfg09080's Avatar
    I keep having problems with Mediaserver on my Z2, when I try to copy videos onto my Z2 (both the internal storage and the SD card) the copy seems to get stuck for a bit and then I get an error message saying that I can't copy "filename" to the device, do I want to skip it, skip all or cancel.
    I also keep getting an error message when I try to charge my phone saying that the power is insufficient to charge my phone and that I need to stop some apps on my phone so it can charge. I wasn't using any apps at the time when I got this error message so I checked my power management section in the settings and Mediaserver was taking up 68% of my battery.
    I've been trying to find a solution to this for a few hours and the only solution i've been able to find so far is to use the mediaserver killer app but when I tried using it my screen just flashes white and it immediately exits out of the app.
    I just checked my power management section again and MediaServer is down to 41% battery useage but this still seems outrageous for something that i'm not even useing
    Any help would be greatly appreciated
    05-03-2014 11:05 AM
  1. Numerous - a drop7 inspired game with powerups
    By DrExK in forum Android Apps
    Last Post: 07-03-2014, 11:14 PM
  2. LG G Flex: Try comparing a day with Knockon...
    By Relgoshan in forum LG G Flex
    Last Post: 05-21-2014, 03:27 PM
  3. Galaxy Tab 3 with WiFi Issues - Help!!
    By myetman23 in forum Samsung Galaxy Tab 3
    Last Post: 05-04-2014, 04:41 PM
  4. Problem with contacts on Moto X
    By Doug B in forum Moto X (2013)
    Last Post: 05-04-2014, 06:32 AM
  5. Lg gpad 8.3 kit kat update problem
    By Maria Roberts in forum Android 4.4 KitKat
    Last Post: 05-04-2014, 03:19 AM
