Results 1 to 19 of 19
    Default Sony Xperia Z2 Camera Overheating Issue!
    When I start to play with the other features of the camera such as AR, video, or anything besides the normal camera setting, it says it's overheating and shuts down!!! I just got this phone. Is this a common problem? How can I fix it and not get the problem again??
  2. Thread Author  Thread Author    #2
    Default Re: Sony Xperia Z2 Camera Overheating Issue!
    Can anyone please help me??
  3. #3
    malt1977's Avatar
    Posts
    Global Posts
    174 Global Posts
    There are many factors such as ambient air temp etc which need to be taken in to account also. Shooting footage in 4K will heat the phone up in a few minutes. Search the threads, this has been gone over a few times already, I'm sure you'll fine what you want to know.
    I didn't even use video. I just used the normal camera settings on there, so far I haven't found a fix on this forum so that's why I'm asking!!
  5. #5
    malt1977's Avatar
    Posts
    Global Posts
    174 Global Posts
    Ok, it's just a little confusing that in your first post you say you'd used video, now you're saying that you don't?. We can only try to help if we're given the correct info. Have you contacted your local sony centre?
  6. #6
    Yes it's a common problem. Using the camera even without video takes a lot out of the camera for some reason. You will not want to use it to take a lot of consecutive pics. The phone will overheat and subsequently shut down, and really drains the battery. It's just the way Sony made it.
    Sent from my D6503 using AC Forums mobile app
  7. #7
    darthhen's Avatar
    Posts
    Global Posts
    333 Global Posts
    I finally made it to my local Sony store to try the Z2. I too noticed how the area near the camera heated up quickly. I was surprised that it heated up quicker than my Lumia 1020.
    Side note.... I took some shots with Z2 and my Lumia 1020 at the store. Both phones set to auto, the color balance on the Z2 was confused. Came out a bit yellow on the shots. I had to set the WB manually to get the proper image.
  8. #8
    I live in Alabama and it is currently august. The outdoor temperature is over 100 degrees (F) and my Z2 overheats pretty quick when outside. What conditions have you been using your phone in? I have yet to have any overheating issues indoors where the temperature is around 75 degrees.
    My thoughts on the Z2 overheating issue is as follow:
    1) this is a high MP camera with a large sensor. This creates a large amount of data to work through.
    2) Sony does some pretty serious post processing on it's photos and video. This will obviously increase power usage and heat.
    3) the viewfinder is quite responsive. One of the best and clearest I have seen on an android phone. This probably adds some additional processing strain.
    4) I think the processor is located near the camera in the body of the phone. The repercussions of this design decision are pretty obvious.
    5) the glass construction may not do a very good job of transferring the heat away from the body of the phone.
    6) I would bet that Sony has picked a lower threshold for temperature tolerance than most other phone manufacturers. This may be because the sensor/other camera components are more susceptible to heat than other phones or Sony may simply be more careful than other manufacturers.
    All of these factors combined seem to have created a pretty serious camera heat issue with the Z2. It makes sense that is would be much worse when the starting temperature is 25 degrees higher but it is disappointing nevertheless.
  9. #9
    It's pretty poor, I agree. Mine kept overheating when I was taking photos (not videos) with filters applied! And this was under 30 degrees. Poor show, Sony.
    To be honest, I am beginning to realise that the quality that Sony was famous for back in the seventies and eighties is now missing, and they seem happy to sell poorly tested hardware, riddled with irritating bugs. Not good enough!
  10. #10
    Quote Originally Posted by robsawalker View Post
    You'll find this true of any manufacturer of consumer electronics these days, some of course worse than other on "quality control" (that's where it varies more than quality itself, IMO). I blame the drive towards ever-cheaper electronics and faster turnover rate (upgrading every X months instead of every Y years, means less quality control, cheaper components, less thinking about long-term durability or usability, and so on).
  11. #11
    That's true, but Apple, for instance, seen to have excellent quackery control and thorough testing, and Sony have been, for me at least, the worst with the phones I have owned.
  12. #12
    Things slip by Apple, too, but yes quality control is higher there. Why I also mentioned both quality and quality control in my reply
    Also, some people hit by lemons will bash Apple's poor quality and quality control, while I have barely had any problem with my Apple products over the years. It's quite hard to judge from anecdotes I suppose.
    As for the worst with the phones, for me it has been Sharp and Fujitsu at the lowest, HTC at the top (haven't owned an Apple phone so far), Sony somewhere in the middle.
  13. #13
    I just bought this z2. And same thing, my fon is experiencing overheating problem when cam is used. Im from philippines where temp is hot. Please tell me there is already a solution for this.
  14. #14
    Not that we are aware of yet. Perhaps a software update may help one day?
  15. #15
    Thanx. But that cant be done. It will void the warranty. Ill just bring this back to the store and then c what'll happen.
  16. #16
    I had brought my sony xperia z2 but it is getting over heating when I used to play games soo please suggest me some the solution
  17. #17
    I came up with solution for overheating camera issue in Xperia phones.
    Remove back panel of yiur phone
    You will find metallic strip around camera sensor
    You have to adjust this metaklic strip in such a way that it should ve in touch wid camera sensor from all sides(if all sides is not possible then get that metal strip as near as possible to camera)
    That metal acts as heatsink for camera.
    Sometimes it is not in touch with sensor.
    Other option you can do us downloaf any other camera app from playstore
    But it cant give high quality image capturing
    However it wont show any temperature warning
    PLEASE Hit Like button if you find my solution is working for you
  18. #18
    This is one of the best suggestions ive heard might try it thanks fo the info mate ...
  19. #19
    when i start using my phone,few min its got heat temperature to 86c,what is solution
  1. Replies: 1
    Last Post: 03-04-2015, 11:25 PM
  2. Sony Xperia Z2 Camera Overheating Issue!
    By ILUMINATIUNDEAD in forum Other Sony Android Phones
    Last Post: 07-19-2014, 12:31 AM
  3. Gear 2 Cam. cool camera app
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 07-18-2014, 05:18 PM
  4. Nexus 7 2013 Issues
    Last Post: 07-18-2014, 05:00 PM
  5. Odd screen issue
    By mhans311 in forum LG G2
    Last Post: 07-18-2014, 03:29 PM
