1. chantheman31's Avatar
    Which is better for the battery in the long run? charging every night at 50-60% or every two days, putting it on the charger at 10% or under? Not a bug deal, just curious... Loving the battery life on this phone.
    08-08-2014 01:34 PM
  2. zedorda's Avatar
    It is better to charge often and remove from the charger when full.
    08-08-2014 02:13 PM
  3. bneisen's Avatar
    Actually, it doesn't matter if you unplug it immediately once its done charging - the phone won't overcharge, it's smart enough not to do that
    08-21-2014 01:24 PM
  4. zedorda's Avatar
    Overcharge is not the problem it is that each time that the battery discharges just alittle the charger will recharge it eating away at recharge cycles and longevity. Plus the more time spent over 90% and under 10% the more stress the battery experiences and again eating away at longevity. Ideally if you can keep your lithium-ion battery between 80%-40% the longer it will last but that is tricky so best effort to balance is all we can do.
    08-21-2014 07:00 PM
  1. Z1 compact battery issues
    By Loui Lebeco in forum Sony Xperia Z1 Compact
    Last Post: 08-05-2015, 05:21 AM
  2. htc one battery life
    By carsonhtconem7 in forum Ask a Question
    Last Post: 08-08-2014, 06:11 PM
  3. More about battery life ... the carriers.
    By jmagid51 in forum Samsung Galaxy S5
    Last Post: 08-08-2014, 05:29 PM
  4. Moto E: Battery draining too fast when it is kept idle
    Last Post: 08-08-2014, 12:58 PM
  5. [Q] [HELP] Battery remains constant and drains to 0 rapidly
    Last Post: 08-08-2014, 06:14 AM
