1. Jump Jet's Avatar
    My Sony Xperia z2 camera ' lens have water vapour !
    what can i do ?
    08-28-2014 04:35 AM
  2. vamp07's Avatar
    My wife's z1 gets this problem easily. Just running it under the faucet will cause it. The water resistance of this phone is greatly exaggerated
    Just put it in a dry place over night like a room with ac and open the doors for the USB port and sd card. The phone and camera will be fine.
    08-28-2014 05:37 AM
  3. pirarre's Avatar
    what can i do ?
    Did you ever get this fixed? I think I got the same problem with my Z3
    01-30-2015 02:04 PM
  4. gunzkevin's Avatar
    Copying this from an old thread where I posted
    It should naturally go away with time. As energy from your pocket and the phone heats up the water, it will evaporate. It condenses when it hits a surface with less energy (colder).
    If you don't want to wait, you can open the micro SD flap on your phone, hold it so this flap is up. Then lightly blow dry the camera area of your phone. Have it set to the lowest heat.
    Really, you could have the blow drier ten feet away and it will work, slowly, but it will work.
    Just don't have the blow drier right on your phone. In a minute or so, it should be gone. Once you are satisfied, close the flap.
    02-01-2015 04:55 PM
  5. LyndaLakyy29's Avatar
    This saved me from opening my phone and risking the water proof seal! Thank you so much!
    06-30-2015 11:40 AM
  6. Saeed Okoroji's Avatar
    You can also just bury under rice for an hour or 2.
    Sent from my D6503 using Tapatalk
    07-05-2015 06:33 AM
  7. Vernon Diaz's Avatar
    I inserted my mobile in rice for mre like an 2 hour bt still thr r vapours on d camera lens n flashlight n evn on front camera.... Plz hlp out any1 wat to do
    09-18-2015 02:04 PM
  8. Vernon Diaz's Avatar
    I buried it bt doesn't wrk
    09-18-2015 02:05 PM
  9. Saeed Okoroji's Avatar
    U buried it in rice with all the ports opened?
    09-20-2015 10:53 AM
  10. chi tam vu's Avatar
    Here is an Amazing fast way to solve this:
    step 1: Open the camera App
    step 2: on the bottom corner of the camera app, you will see the downloadable camera apps
    step 3: choose the AR or 4K recording app
    step 4: record a video and the phone will get hotter and the water vapor will slowly disappear
    10-14-2015 08:06 AM
  11. Enshaaf Ahamed's Avatar
    No. i put my Z2inside a plastic cover n buried it in the rice and all the flaps were closed
    12-17-2015 08:06 PM
  1. clip on camera?
    By NickDomi in forum Ask a Question
    Last Post: 04-06-2015, 01:55 AM
  2. How to restore Sony Xperia V to 9.0.D.0.484 (4.0.4 ICS)
    By Promon Tester in forum Ask a Question
    Last Post: 08-29-2014, 03:00 AM
  3. Problem installing Custom ROM. Please Help
    By SayIDidIt in forum Samsung Galaxy S3 Mini
    Last Post: 08-29-2014, 02:54 AM
  4. hdmi switch, i need help.
    By Unregistered in forum Ask a Question
    Last Post: 08-28-2014, 10:54 PM
  5. Water damage to S5 help plz
    Last Post: 08-28-2014, 07:59 AM
