1. AC Question's Avatar
    Hi, hope someone can shed some light on this problem I have.
    I recently replaced the screen and back on my Sony xperia Z3 compact but now have no sound and the volume button only goes down.
    I have looked this up on Google and it says that you should replace the flex cable and that will solve the problem but mine doesn't have a flexible?
    Any ideas what else would cause this?
    Many thanks
    03-17-2017 04:35 PM
  2. Tim1954's Avatar
    Disassemble it again carefully and you may spot some contact not being in the right place, or some wire not being plugged in.. Check any cables thoroughly for breaks, pull off all connections (that you disconnected last time) and push back in again firmly.
    If you have no joy, probably a repair shop where they have the tools and diagnostic equipment to test everything...
    03-17-2017 08:03 PM
  1. Galaxy S4 does not factory reset after multiple attempts
    By Dracowyrm in forum Sprint Samsung Galaxy S4
    Last Post: 03-20-2017, 07:43 AM
  2. Replies: 3
    Last Post: 03-20-2017, 04:35 AM
  3. Were are all the songs i down load going
    Last Post: 03-17-2017, 05:57 PM
  4. Replies: 0
    Last Post: 03-17-2017, 03:28 PM
