What wireless charging pad are you guys using? Nokia's DT-910 charging stand is unstable.
Roy Droid
107
I have a Nokia DT-910 charging stand. It only charges in the vertical position which makes it very unstable. Any bump will knock it off its base.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
I've been using the Lugu Lake pad for months. Cheap and the "sweet spot" is pretty large.
But unless that pad has something running up the back, your receiver coil is on the bottom of the phone, so it'll have to be charged in a vertical position regardless of which pad you use.
JLee1469
TYLT vu, always charged since its a fixed position. Have had good luck with the powerbot qi car mount as well.
Sent from my Nexus 7 using Tapatalk
pchain
227
12
18
TYLT VU for me as well. Really good reliable charger. Sometimes I wish it was angled just a little bit more upward though.
