Dear sir,
I have a xperia Z3V. It was rooted by me. It worked fine until a major mistake. I flashed a zip file. After flashing that zip file my phone won't turn on. When I connect to wall charger only red led blinks frequently. When I connect to my laptop , red and green led blinks frequently.
I tried to flash firmware by flash tools.But it does not go to flashmode option when I press volume down key. But when I press volume up key then it goes to fastboot mode. Also I am able to go factory mode when I press and hold power and volume down key together and I see following 4 options
1. Continue power up
2.Safe mode
3.factory reset
4.Power down
but no option can make my z3v alive.
I tried PCC also. but did not detect my phone.
So would you please suggest me regarding the possible solutions.
2.Safe mode
3.factory reset
4.Power down
