Results 1 to 4 of 4
    kojisan's Avatar
    Posts
    Global Posts
    167 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default KitKat and Battery Drain
    Not sure if anyone else has had enough time with KitKat to test but I updated yesterday and my battery life has tanked.
    "Google Services" appears to be the culprit. I've installed GSAM to get a better read of what is going on but the bottom line is that the phone will not last through the day now! It's terrible. I wish I could revert the OS.
    Anyone else out there?
  2. #2
    Fabio Bix's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: KitKat and Battery Drain
    same problem.
    battery last 5 to 6 hours
    google services look to be the responsible
  3. #3
    freask's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My advise is downgrade to 4.3 version.
    After up to 4.4 becomes the problems with my ZL (fast discharge of the battery, and after my ZL didnt turn on becuase accumulator was die)
  4. #4
    FRISCO2011's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had my zl since july of 2013 and my problem started yesterday just kept shutting off..... today was fully charged and after 95% it won't power on without the cable so what should I do get a new phone or try to get this one fixed and only due for an upgrade next May..... loved it til this happened
  1. Galaxy S4 major battery drain issues.
    By Cali Calin in forum Samsung Galaxy S4
    Last Post: 07-16-2014, 06:42 AM
  2. Replies: 9
    Last Post: 05-23-2014, 02:05 PM
  3. Low Battery LED Light
    By sparko24 in forum Droid RAZR MAXX HD
    Last Post: 05-22-2014, 01:32 PM
  4. Google Play books and Dot view case
    By Christian Farhat in forum HTC One M8
    Last Post: 05-22-2014, 01:20 PM
