Results 1 to 11 of 11
    momsescape's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default all my calls are going to voicemail!! help!
    I am not sure what I have done, but my phone no longer rings, all calls go immediately to voicemail. and when I click on the right button where it used to let me chose airplane mode, silent, etc it just says phone options. Does anyone have any suggestions on how to fix this?
    Thanks so much!
    Jenn
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: all my calls are going to voicemail!! help!!
    This may sound silly but have you rebooted the device? Do a battery pull and try a reboot and see what happens...
  3. #3
    dtm_stretch's Avatar
    Awesome Possum
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSP JB/CM9
    Quote Originally Posted by momsescape View Post
    Thanks so much!
    Jenn
    Have you tried pulling the battery and restarting it? Also are you running stock or rooted?
    *You got me this time Paul
    momsescape's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have pulled the battery, and I am running stock. the only app I have added is a task killer and I uninstalled that.....I am not sure what I could have done to loose the phone options on the side power button too.....wondering if i should try a factory restore??
  5. #5
    Awesome Possum
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOSP JB/CM9
    Default
    That would be my recommendation. Just be aware you are going to lose all your data
  6. #6
    revinger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have had my thundwrbolt go into that mode twice, borh were my fault though and also couldnt plqce calls. I had putbthe phone into evdo only mode. Let me lock to 3g and do data, but had the unwanted side effect od not allowing voice calls.
    Sent from my ADR6400L using Tapatalk
  7. #7
    Devtodi's Avatar
    Posts
    Global Posts
    734 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7 alpha 1
    Sounds like you signed up fo google voice which was a big mistake. If that is the case, you need to talk to Sprint and they can disable it.
  8. #8
    alestin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are you using Sprint Airave device by any chance? Sometimes phones in airave coverage will not ring and all calls go straight to voicemail...
  9. #9
    werkx's Avatar
    Posts
    Global Posts
    361 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i get that when i'm in bad reception area. it could have something to do with your radio if you are not in a bad area. usually a reboot resets the radio.
  10. #10
    dchawk81's Avatar
    Posts
    Global Posts
    1,539 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check your menu settings to see if you have the DDTM box ticked.
    Settings > Call Settings > DDTM
  11. #11
    Daniel Goldszmidt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is what happened to me.
    I connected my cell to my pc through a bluetooth connection.
    Then every incoming call got immediately connected to the loudspeakers , after just one ring.
    Check it up.
