Results 1 to 8 of 8
- 11-13-2011, 08:03 AM
Thread Author #1
Help with GPS issue after GB update?
After doing the manual update to GB, it seems the GPS will only stay locked for several minutes at a time. I've seen here that the fix is to do a hard reset and then re-do the GB update, I think. I'd appreciate any help with this since I have very little experience with this type of stuff and I'd like to be sure I get it done right the 2nd time.
My phone is stock, no rooting. - 11-13-2011, 09:39 AM #2
Re: Help with GPS issue after GB update?
You would need to use the following... Procedure #1 from the thread below.
[How to] Factory Restore (or Fix a Bricked Phone)
That will make your device as it would be stock out of the box on Froyo EC05.
Note: Only "true" GPS fix I know of if that doesn't work is to root your device and use a GPS mod/hack that is available...
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 11-13-2011, 10:36 AM
Thread Author #3
- 11-13-2011, 10:41 AM #4My history: Ericsson 628, 768, T10, T28 World, Siemens S12, Nokia 8290, 3390, Motorola C330 , V70, Ericsson T68i, Motorola v100, Accompli 009, Sony Ericsson P800, T300, T610, O2 XDA II, BlackBerry 6210, Sanyo SCP5300, SCP8100, VM4500, PM8200, MM7400, MM8300, MM9000, BlackBerry 7750, Kyocera KX18, MM-A900, SCP8400, Pearl 8130, Tour 9630, Samsung Epic 4G, HTC Design 4G, Nook Tablet. CO's: Omnipoint, Voicestream, T-Mobile, (Amp'd for a short time) Sprint, VerizonThanked by 2:
- 11-13-2011, 10:49 AM
Thread Author #5
- 11-13-2011, 10:57 AM #6
in CWM...
the cache and the dalvik cache in advanced... I am running the stock odexed... rooted...
You need CWM and rooted to work... You can use a back up program to back up your date before hand... I personally prefer rooted because it is the only way to perform REAL full back-ups..Last edited by mike340t; 11-13-2011 at 11:02 AM.
My history: Ericsson 628, 768, T10, T28 World, Siemens S12, Nokia 8290, 3390, Motorola C330 , V70, Ericsson T68i, Motorola v100, Accompli 009, Sony Ericsson P800, T300, T610, O2 XDA II, BlackBerry 6210, Sanyo SCP5300, SCP8100, VM4500, PM8200, MM7400, MM8300, MM9000, BlackBerry 7750, Kyocera KX18, MM-A900, SCP8400, Pearl 8130, Tour 9630, Samsung Epic 4G, HTC Design 4G, Nook Tablet. CO's: Omnipoint, Voicestream, T-Mobile, (Amp'd for a short time) Sprint, Verizon - 11-13-2011, 11:07 AM
Thread Author #7
- 11-13-2011, 02:56 PM #8
Before you take the leap read about it ! Trust me you will save yourself headaches lol..
For just current official GB: Rooting EI22 Gingerbread Instructions
Also, read around the hack/root forums.. Lastly, XDA is where most comes from for hacking/rooting but tread carefully and slowly and you'll be fine
My history: Ericsson 628, 768, T10, T28 World, Siemens S12, Nokia 8290, 3390, Motorola C330 , V70, Ericsson T68i, Motorola v100, Accompli 009, Sony Ericsson P800, T300, T610, O2 XDA II, BlackBerry 6210, Sanyo SCP5300, SCP8100, VM4500, PM8200, MM7400, MM8300, MM9000, BlackBerry 7750, Kyocera KX18, MM-A900, SCP8400, Pearl 8130, Tour 9630, Samsung Epic 4G, HTC Design 4G, Nook Tablet. CO's: Omnipoint, Voicestream, T-Mobile, (Amp'd for a short time) Sprint, VerizonThanked by:
Reply
