Results 1 to 10 of 10
    Default Help! Epic 4g stuck on safe mode
    I've tried everything from taking off the battery to going into recovery mode but the volume buttons don't work to scroll down. I've already done a soft factory reset with the phone on but it still stays safe mode on the lower left hand corner of the screen. Please help guys. Thanks
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    14,045 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: Help! Epic 4g stuck on safe mode
    Quote Originally Posted by jroush View Post
    Thats strange... I had a few safe mode boots before when I had my Epic... Normally a reboot always resolved the problem.
    If the factory reset, reboot and battery removal hasn't done anything you may want to take a trip to your local Sprint store...
    BTW, have you pulled your SDCARD and tried booting up and see if that changes things? Sometimes a faulty SDCARD can cause strange things to happen....
    yes i did and still nothing. So frustrating. The phone still works just has the safe mode on lower left corner. The volume down key doesn't seem to work but the volume up does.
  4. #4
    Paul627g's Avatar
    Posts
    Global Posts
    14,045 Global Posts
    ROM
    Sounds like your having some sort of hardware problem. Could be software but you said you've done a factory reset.....
    Only other option if you willing to try is doing a manual factory reset using Odin. Same tool we use in rooting a device and flashing radios, kernels, ROMs ....
    Its up to you but it will allow a complete full wipe and re-installation of the OS to the device and then you can completely rule out software.
    [How to] Factory Restore (or Fix a Bricked Phone)
    Procedure #1--- Froyo EC05
    Once you complete the process you should receive the OTA update to EI22 not too long afterwards. You can choose to update or stay on EC05 either one is official OS and can be taken in for service as is.
    Thanks alot for helping me out with this situation. I will use Odin to do a full wipe then i will get back to you. Again, thanks
  6. #6
    Tried flashing my samsung galaxy sII epic 4g touch back to stock with odin, it failed and now i'm stuck at the android system recovery menu and i cannot press my home button or menu button to reboot system. It says the following: Deleting Cryption Meta Data
    --copying media files....
    successfully copied media files.
    #manual mode#
    --updating application...
    successfully updated application...
    --Appling multi-CSC...
    successfully applied multi-CSC
    Stuck in this menu and cannot press my home button, or menu button. Please Help.
  7. #7
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Default
    Quote Originally Posted by dstrizzy84 View Post
    #manual mode#
    Wrong forum.
    Sent from my SPH-D700 using Tapatalk
  8. #8
    well im new to all of this. And im panicking..too much stuff to sift through to post my comment
  9. #9
    I Have The Same Promblem !
    But Mines Just Turn ON & Shuts Off Like 5 seconds After Staring The Cel... And It Turn On Again By It Self & Off Again By It Self.. I Was All Summer With THis And I Need My Celphone.. Please Some One Help Me...
  10. #10
    Quote Originally Posted by JanMaycoll View Post
    That's a bootloop. It's not actually shutting off. You may need to odin back to stock, especially if you have not attempted to root or do anything else with it. If you have, than restore your most recent working nandroid backup, and you should be OK.
    Sprint Galaxy Nexus [stock for now]
    BB 8130, iPhone 4 8g, iPhone 3g 16gb, Toshiba e800, Palm Tungsten T
    [retired]Epic 4g, BB8330, BB 9670, Samsung Intercept, Katana DLX, Sanyo 8400, HTC Wizard, MPX220, and many others...
