Results 1 to 2 of 2
    Default Power button does not work.
    Hello, I recently had a problem with my epic 4g in which my power button, camera button, and the top and bottom row of my qwerty keypad did not work. I recently bought a new keyboard flex and frame port for my phone and I put it in. Unfortunately my power button still does not work and the only way I'm able to turn it on is by rapidly plugging and un-plugging the charger. However, my other buttons work fine.
    I didn't Gingerbread update my phone since I always run into installation problems. Any suggestions on what I should do that doesn't involve taking it to a Spring Repair center?
  2. #2
    Default Re: Power button does not work.
    You can try to make sure the power button is installed correctly, it may have slipped a little during install. If that doesn't work, remove the "button" and use a small non-sharp (ball point pen works well) item to push the contact. If THAT doesn't work than it could be a connection on the board. Either track the parts that aren't working, or let Sprint take care of it. The service centers really aren't all that scary
    Sprint Galaxy Nexus [stock for now]
    BB 8130, iPhone 4 8g, iPhone 3g 16gb, Toshiba e800, Palm Tungsten T
    [retired]Epic 4g, BB8330, BB 9670, Samsung Intercept, Katana DLX, Sanyo 8400, HTC Wizard, MPX220, and many others...
