DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 5 of 5
    Default Battery usage from 'android system'
    Lately, the 'android system' has been draining my battery. I used to have background sync on, but turned that off. I have the display set on automatic.
    I am running Pandora a lot, but according to the battery usage summary, Pandora is just 2% of what is using the battery.
    I now have to rely on my spare battery since just one battery doesn't last the day. Has the battery developed a 'memory' so that it isn't fully charging?
    Sent from my SPH-D700 using Android Central Forums
  2. #2
    drekosh's Avatar
    Posts
    Global Posts
    110 Global Posts
    ROM
    CM9 Beta 2
    Default
    Someone could tell me I'm wrong, but I don't think the batteries in these phones develop a memory.
    Have you downloaded any new apps lately or changed ROMS?
    Sent from my Transformer TF101 using Android Central Forums
  3. #3
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Default
    They have no memory. Also, by using Pandora it keeps your system awake. I would guess that it just shows the usage as system because (and I'm assuming) your running Pandora with the screen off and the application in the background.
    Sent from my SPH-D700 CM9 ANDROID 4.0.4
    Default
    I am running Pandora with the screen off, so is it in fact this app that is running the battery down and it's being reported as the android system?
    I have put most of the apps back on after a factory reset. I guess that I need to watch which apps require running in the background.
  5. #5
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Default
    What build are you running?
