Results 1 to 4 of 4
    Question HELP! Stuck in Recovery & home screen is unresponsive
    My Epic 4G was constantly powering off & I read that a reset was the way to go... so I was able to get into recovery mode but now I can't select an option b/c my home button on the touch screen will not do anything.
    I searched the forums & saw that the camera button might work for selection... tried that & it didn't work for me. Is there a manual or keyboard way to choose the selection or back out of recovery mode?
    Thanks in advance!
  2. #2
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Default
    Pull battery and reboot. There should be an option to do a data reset from within Android. It will boot to recovery and perform the action automatically.
    Sent from my SPH-D700 CM9 4.0.4
    Default Re: HELP! Stuck in Recovery & home screen is unresponsive
    Every time I take out the battery & put it back in then power on it's still on the recovery mode screen. I can make it go into download mode by pressing 1 on the keyboard & power simultaneously but I don't know how to make it power on as normal since my touch home button won't respond and I don't know of a keyboard button sequence to do so.
  4. #4
    Out of curiosity, have you tried to use the physical "home" button on the keyboard?
    Sprint Galaxy Nexus [stock for now]
    BB 8130, iPhone 4 8g, iPhone 3g 16gb, Toshiba e800, Palm Tungsten T
    [retired]Epic 4g, BB8330, BB 9670, Samsung Intercept, Katana DLX, Sanyo 8400, HTC Wizard, MPX220, and many others...
