Results 1 to 11 of 11
- 08-25-2012, 05:30 PM
Thread Author #1
Android System Battery Use
The Android System is using up a significant amount of the battery. I bought an extended use battery and thought that I would rarely have to use it, but I can't get through a day without having to switch batteries.
The average battery time I am getting lately is 4.5 to 5 hours. The Android system is using about 70% of the battery. Some days, the only application I use is Pandora. I keep the screen off and have disabled background data to save the battery, but it doesn't seem to be helping.
I talked to a Sprint rep at a store about the battery use, and their suggestion was to reset the phone because they thought something must be wrong with the phone for the Android system to be using that much of the battery. They also said that trying to figure out what part of the Android system was using the battery was difficult to figure out.
Sent from my SPH-D700 using Android Central Forums - 08-26-2012, 10:28 PM #2
- 08-27-2012, 01:38 AM #3
Task killers... Don't make me laugh.
Use betterbatterystats to find what's keeping your system awake, correct the issue accordingly, then remove betterbatterystats. It can be found on the Play Store as well as XDA Forums. XDA Members get the app free.
Sent from my Stock AOSP Android 4.1.1 Galaxy Nexus - 08-27-2012, 11:59 AM #4
- 08-27-2012, 05:50 PM #5
Re: Android System Battery Use
I also have been having this problem. I even lose 5% an hour on airplane mode. And it does looks like the system is being kept awake by something.
Batter battery stats is a paid program. Is there something else?
I am running Cynagenmod 9 beta3. I am thinking about upgrading to the new stable version, but it is too much work if I am not sure it will help much... - 08-27-2012, 06:58 PM #6
- 09-09-2012, 08:22 AM
Thread Author #7
I've looked into the battery use issue a bit more, and what I found was that applications that were not being used were running in the background. For example, TeleNav (formerly Spring Navigation) is an application which I rarely use. I've used it a few times when Google Maps kept stating 'GPS signal lost' -- I wanted to see if TeleNav would report the same problem. TeleNav is running in the background and everytime I attempt to stop it, it starts right back up again. Google Maps is also running in the background. If I don't have the GPS on and I don't have Google Maps open, why does it need to run in the background??? At least with Google Maps, it seems that I can stop the process from running.
These are just a couple of the overall apps/processes that are running in the background. The maximum amount of time I can get now on one charge is 4.5hrs -- I can extend that with a portable charger and get a few more hours. Even the extended use battery that I purchased from Android Central is running down in 4.5 hours. - 09-09-2012, 03:27 PM #8
- 10-22-2012, 09:55 PM #9
Google Maps does have a service, NetworkLocationService, that starts up when Maps runs and doesn't shut down when Maps is closed. Even disabling the cell and WiFi network location services didn't get rid of it. It was sucking a lot of power for nothing (except perhaps to keep Google updated on my whereabouts for traffic reporting, etc.). So, I fixed it by disabling the NetworkLocationService since I only need GPS for location data when using Maps (disabling apps/services requires Ice Cream Sandwich or newer, or if you're rooted you can freeze it with Titanium Backup).
My power consumption went from 4-5% per hour when idle to 1-1.5% per hour. - 10-24-2012, 09:09 AM #10
- 10-25-2012, 11:02 PM #11
Reply
