DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Default Using Epic for Bluetooth and Audio Out together in car
    My car has bluetooth for calls which is working great alone.
    But when I also plug in a 3.5mm cable for playing music over the car stereo, my bluetooth calls can't be heard anymore. I guess the phone thinks i have headphones plugged in or something.
    Has anyone else ran into this and found a solution? I'd really like to use my Epic for music in the car also so that I can get rid of my Ipod. The only solution I came up with was unplugging the 3.5mm cable everytime i get a call in the car. :rolleyes:
  2. #2
    debello's Avatar
    Posts
    Global Posts
    44 Global Posts
    Default
    The stereo won't play the music over Bluetooth?
    Default
    Nope. My car doesn't support that feature.
  4. #4
    project.in.process's Avatar
    Posts
    ROM
    Bamf Paradigm
    Default
    You're correct--the phone won't allow this function.
    a good way around it is to purchase a Bluetooth transmitter/FM transmitter from Bestbuy (think Jabra)
    i bought one from Amazon for $59, bestbuy sells them for $99.
    the device features the ability to transmit music from your phone to the transmitter (via bluetooth) and then sends that music signal to your radio---just like a wireless FM transmitter on any mp3/ipod.
    when you receive a call, the device then pauses your music, and you can answer your calls simply by touching a button on the device. when the call is ended, the music resumes and the phone continues transmitting the music to the device--the device then continues transmitting the music to the radio.
    there are alot of Jabra sets out there, make sure you read the specs to see that it supports your version of bluetooth.
  5. #5
    Default
    The fact that the EPIC can't override music to take a call when connected to your car stereo via aux is a deal breaker for me.
    Is this a known issue? Or just a guess?
    I am coming from a iPhone 3g and it does not have this problem. Is this the norm with all Android phones or just the EPIC/Samsung droids?
    My phone is being delivered via UPS tomorrow and Im going to refuse it if this is indeed the case.
  6. #6
    Andrew Ruffolo's Avatar
    Posts
    Global Posts
    3,815 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by quibbs View Post
    This is how I made hands free calls in the car. It will broadcast call audio through the aux cable, but still take in audio through the standard mic. Not having bluetooth in the car makes this really nice. My mom's car, which I drive occassionally when she needs my suv, has bluetooth and aux in. It doesn't support bluetooth audio. There may be an app that can direct music through aux and calls through bluetooth. I don't know of any, but I've used ROMs on my Hero that had more audio management apps that I knew what to do with.
  7. #7
    Default
    Thanks for the info Andrew.
    Unfortunately, for me at least, it's difficult to lose a feature that I use on a day to day basis. It's a step back to have to look for a solution that may, or may not be there. I just assumed it would work right out of the box. Until I can find a Android phone with this ability (that I want) it appears I am stuck with my old phone... :/
  8. #8
    Posts
    Global Posts
    3,815 Global Posts
    ROM
    Stock
    Default
    Yeah, I don't know if it does or doesn't Gotta wait for my mom to get home to test it out on her car. Since her's doesn't support Bluetooth audio, it would be a good test.
    Thanked by:
    quibbs
  9. #9
    Ricolando's Avatar
    Posts
    ROM
    Stock 4.2 Jellybean
    Default
    My car supports calling and music through bluetooth. I'll check tomorrow to see if the Epic can manage both at once even though I use an ipod touch for music since my library is almost 50 gb.
    Thanked by:
    quibbs
  10. #10
    Default
    Quote Originally Posted by Andrew Ruffolo View Post
    Yeah that was my preferred method but it doesn't work on the epic 4g. When the audio jack is plugged, all microphones are disabled. I think it assumes you have plugged a wired headset. so i assumed that if I bought a bluetooth, I could get around the issue that way. no dice. when audio jack is plugged, no other output can be selected
  11. #11
    Default
    I started a trouble ticket with samsung. ticket # is 2007-713-975
  12. #12
    Default
    Quote Originally Posted by mredamon View Post
    how do i communicate to samsung based on your ticket #?
  13. #13
    Default
    Quote Originally Posted by ercsliberty View Post
    I assume you call support and open your own ticket on the subject. That would be most effective
  14. #14
    Default
    Quote Originally Posted by project.in.process View Post
    How is the quality of the transmitter? I like the phone but using the bluetooth has been a pain.
  15. #15
    Default
    You cant even use that method with a bluetooth. I had the same problem so I bought a bluetooth headset.
    I would be driving my car listening to music with the AUX jack. My bluetooth is on and connected. When call comes through it will use the bluetooth headset's mic but play the call through the Aux jack. So dumb. True hands free calling is impossible on this phone. My EVO 4g had no problems with this.
  16. #16
    Default
    Wrong. When you plug in the audio jack the phone's mic still works. I just used that on a call last night in my truck. Audio over the car stereo and the caller on the other end heard me just fine. I don't know how Bluetooth plays with AUX, since I don't use Bluetooth. But, it seems unnecessary since the mic on the phone works.
  17. #17
    Default
    I updated to di18 and I no longer have this issue, also my microphone works now even while audio jack is plugged. Thanks sammy and sprint.
  18. #18
    Ricey20's Avatar
    Posts
    ROM
    TrulyEpic Rebirth v1.2
    Default
    Tested and bluetooth indeed works like how it's supposed to after DI18 update. Also tested Shazam and Soundhound and these 2 apps work now as well. Wouldn't work before if u had a bluetooth headset connected because the phone mic was disabled if you had bluetooth turned on and had a headset paired (even if it was not connected)
  19. #19
    Default
    Quote Originally Posted by amdille View Post
    "wrong" oooooh so assertive. Actually im not wrong, you just have the most recent firmware. Issue was confirmed and duplicated by samsung tier 2 support. Thanks for playing.
  20. Thread Author  Thread Author    #20
    Default
    I'm still having the issue after the update. Anyone else?
  21. #21
    Default
    I have a 2006 infiniti with bluetooth, but not audio bluetooth and no jack for audio out. will this work with this car? I don't know how to get audio to the car stereo without a jack and with no bluetooth audio!
    thanks!
  22. Thread Author  Thread Author    #22
    Default
    Quote Originally Posted by mcp6530 View Post
    thanks!
    I think an FM transmitter would work for you.
  23. #23
    Default
    i have a cassette player car radio with a cassette adapter with 3.5 outlet. and when I use that with my bluetooth ear piece i have to unplug the adapter to use my bluetooth. there must be a fix or something for this.
  24. #24
    Default
    I have the same problem. I have a 3.5mm aux input and a bluetooth that doesnt support anything but calls. When I receive or place a call while listening to mp3's my cars bluetooth system switches to "Phone" mode. The audio goes completely dead and I hear neither call nor mp3's. My assumption is that the phone is still trying to output the audio to the wired connection for some reason. Seems weird that the car bluetooth even connects if the phone isn't putting out any audio. I've tried updating all of the things that the phone will let you update to no avail. Though I don't know what it means, the "baseband version" indicates that I have DI18. This is infuriating. I don't want to unplug the wire every time I make or receive a call. That's why they call it a "hands free" system. This is a must fix for Samsung.
  25. #25
    Sensai28's Avatar
    Posts
    Global Posts
    27 Global Posts
    Default
    I was having the same problem using the aux input on my car stereo. I have an ipod connector on my car stereo, so I got an Anycom FIPO Bluetooth Stereo Receiver w/Dock Connector for iPod Speakers from Geeks.com
    I can connect to both my bluetooth headset and the FIPO receiver at the same time. I can play music through the stereo; and the phone switches to the headset when I receive/make a call.
