1. Devtodi's Avatar
    When I plug into my computer (64 bit Windows 7) - the card is identified but when I click on it, I am asked to insert a disc - on the phone, I get the red triangle with the exclamation point - Have I done something wrong?
    09-02-2010 10:54 AM
  2. dvdqnoc's Avatar
    Are you trying to plug it into your computer to use it as a USB storage? Or just to charge?
    09-02-2010 11:00 AM
  3. Devtodi's Avatar
    was gonna uploadload some music, photos etc
    09-02-2010 11:02 AM
  4. dvdqnoc's Avatar
    When you plug it in, is there an option on the notification window for you to select charging, USB storage, sync, etc?
    09-02-2010 11:05 AM
  5. Devtodi's Avatar
    no, no options, I get a USB indicator and the red triangle with the exclamation - I can go into settings and see that the card is mounted but cannot communicate with it
    09-02-2010 11:11 AM
  6. dvdqnoc's Avatar
    Is USB debugging on or off?
    09-02-2010 11:13 AM
  7. Devtodi's Avatar
    how do i find out? I think thats what the red triangle is, so I would say yes
    09-02-2010 11:17 AM
  8. dvdqnoc's Avatar
    go to your homescreen
    Menu > Settings > Applications > Development
    uncheck USB debugging, and see if that works...
    09-02-2010 11:29 AM
  9. Devtodi's Avatar
    YES! thanks - that did the trick!
    09-02-2010 11:31 AM
  10. dvdqnoc's Avatar
    No problem! Glad I could help
    09-02-2010 11:32 AM
