1. that.rick22's Avatar
    I just got my Epic and love it but the battery is something I hate... coming from a BlackBerry I am used to a longer life in battery but I understood that with it being a touchscreen it was going to drain but is it suppose to drain so quickly
    i have done all the tricks (cancelling the DRM, the airplane toggle, auto brightness and lowest screen time out) installed Advance Task Killer and i have a battery meter on my Sense Analog Widget
    and I go through then a less average use on my phone but even in idle I see it drain the battery at least a percent around 10 to 15 mins...
    is the Sense Analog battery meter wrong or is there a more accurate one?
    or is there more battery tips i haven't tried yet.
    also, would this battery have that drain to reset the batter memory thing i used to read... like drain the battery fully to cycle the battery
    i would greatly appreciate any help
    11-12-2010 12:29 PM
  2. Butters3605's Avatar
    How is your signal quality, searching for 3G/4G can really suck your battery. I am able to be on WiFi most of the day, and my battery is lasting all day.
    11-12-2010 12:36 PM
  3. jzh797s's Avatar
    I installed JuiceDefender and it seemed to help some... my battery still isnt great. IDK about this phone. Everyone reports GPS taking a long time, but mine is just inaccurate. It can show my position down the Highway, but when I take the off ramp it doesn't know I'm not on the Highway until Im under it and past it. My Touch Pro never had problems like this... it knew when I walked from one room to the next in my house on Google Maps.
    11-12-2010 12:40 PM
  4. PhantomPhreak53's Avatar
    Download Battery History from the Android Market. It's free. Let it run through a normal day of usage. It is just a report but you can at least see if a certain app is killing the battery. When you open Battery History, choose the partial wake option. Those are the apps that prevent your phone from fully sleeping when it's idle.
    11-12-2010 12:47 PM
  5. Butters3605's Avatar
    Also, check out the program monitor widget, see if you have programs running that you thought you had closed. It is a TW widget, may have a battery drain from a program constantly running in the background.
    11-12-2010 01:08 PM
  6. Butters3605's Avatar
    Check out GPS test in the market, It takes min about 30-45 seconds to start picking up GPS satellites. yesterday it locked 9 and was using 9. Also have the cold start fix, I am not off network that often so cold start is no biggie for me.
    11-12-2010 01:10 PM
  7. that.rick22's Avatar
    thanks for the help i am downloading what suggesting you offered and I was wondering if it was my service so I did a PRL and updated my profile and I have great coverage in the area i live in san diego but it still seems to drain....
    would the drain the battery trick work or is that just a myth
    11-12-2010 01:48 PM
  8. acegolfer's Avatar
    Contrary to common belief, advanced task killer CAN become a battery hog. The androidcentral podcast has explained this several times.
    11-12-2010 01:48 PM
  9. that.rick22's Avatar
    i have been wondering that as well... since the Epic does have it's on task manager is it redundant to have ATK as well since we can a clear view of what is actually running when we do a running service check?
    11-12-2010 02:04 PM
  10. taylormah's Avatar
    Is this the Battery History app you are talking about??
    11-12-2010 02:11 PM
  11. PhantomPhreak53's Avatar
    Yes.
    11-12-2010 02:48 PM
  12. jzh797s's Avatar
    I DL this program and it says I have a 98.something Feet accuracy. I have 10 out of 10 locks. Is this normal?
    11-12-2010 07:54 PM
  13. boomerbubba's Avatar
    The 98.4-feet accuracy (really 30.0 meters) is not normal, but it is universal. That is because every Epic 4G shipped has a bug that hard-codes the estimated accuracy at 30.0 meters. That is one of the GPS bugs on the Epic. What is normal in an Android with a correctly functioning GPS is that the estimated accuracy is a dynamic variable, typically changing from moment to moment depending on conditions.
    The bogus figure in question is only the estimated accuracy. The actual accuracy of the lat/lon fix is usually pretty good -- once a good multi-satellite lock is achieved. The worst GPS bug is dependent on time and conditions, the result of buggy handling of time-sensitive GPS cache data. It is that bug that the Cold Start workaround mentioned above addresses.
    11-12-2010 09:43 PM
  14. Andrew Ruffolo's Avatar
    Froyo seems to handle pretty well with battery life ;-)
    11-12-2010 10:08 PM
