Results 1 to 10 of 10
- 04-18-2012, 12:17 PM
Thread Author #1
- 04-18-2012, 12:59 PM #2
Re: Unlock the bootloader if I am not going to flash custom Roms?
Well you could unlock the bootloader at time of purchase and leave it unlocked for the reason of chance that you may in the future load up a different radio, maybe a new leaked update, anything..
Bottom line, the whole thing with the boot loaders on the Nexus is they wipe the device when you unlock them. So if you do it from the start and say a month or 3 months later you want to do something its done, its unlocked.. Throw CWM on there and root and do whatever, your not going to loose you valuable data at that point. On the other hand you leave it locked and then decide man I want to check out this new leaked radio everyone is raving about that's improving signal but now I'm going to loose all my information when I unlock the boot loader.
Its personal preference but as simple as it is to unlock it and continue on using your device it may just save yourself a headache of loosing all that valued info down the road.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 04-18-2012, 01:02 PM
Thread Author #3
Thanks for the info Paul. Can you recommend a trusted set of steps to follow?
This method looks pretty straight forward Do you think it will work for the Sprint LTE version?
Thanks again!Samsung Galaxy S4 - 4.2.2
Samsung Galaxy Nexus - 4.2.1
HTC EVO 4G - 2.3.5 - 04-18-2012, 01:05 PM #4Former moderator & advisor.
HTC - the One to rule them all.
- 04-18-2012, 01:07 PM #5
I agree with dmmarck. The device will have to get released and tested with the current GNex methods of unlocking/rooting. Chances are good it will work but you never know if Sammy & Sprint did something different to the device.
- 04-18-2012, 01:13 PM
Thread Author #6
Perfect...Thanks once again.
Request - If somebody reading this gets a hold of this phone on Saturday, please update this thread with the method used to unlock.
Thanks in advanceSamsung Galaxy S4 - 4.2.2
HTC EVO 4G - 2.3.5 - 04-18-2012, 01:14 PM #7
No problemo
- 04-18-2012, 03:16 PM #8
- 05-03-2012, 05:39 AM #9
I used My Backup Pro to backup my data then un-locked & reinstalled. I had a couple of settings that didn't keep but otherwise, great! I backed up to my internal (no As card) , saved that on my desktop & reinstalled after unlocking.
- 05-03-2012, 05:40 AM #10
Sorry, meant to say no SD card.....
Reply
