Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree2Likes
    Default Sprint Galaxy Nexus extended battery?
    My friend on Verizon has an extended battery that gets him 12 hrs of talk time, my Sprint GNex is around 4 hours or less whether I'm talking or not. Anyone know if/when Sprint is releasing an extended battery or if the Verizon extended battery would work in my phone? The guy at the Verizon store said he wouldn't risk it....
  2. #2
    Default Re: Sprint Galaxy Nexus extended battery?
    you can talk off the battery door and do a comparison. Im sure the electrical needs of the phones are the same, given that they run the same radios, albeit on different spectrums.
  3. #3
    Sprint has no lte sim. I think the battery looks like the gsm version personally
  4. #4
    I have in my hand my father's Sprint Galaxy Nexus with my Verizon Galaxy Nexus' Extended Battery in it and it works just fine, even the NFC works.
    Current Device(s):
    T-Mobile Monthly4G - LG Nexus 4 16GB (from Google Play)
    Asus Transformer Infinity TF700T
    Asus Nexus 7 16GB
    Thanked by 2:
  5. #5
    Bestphonever's Avatar
    Posts
    Global Posts
    135 Global Posts
    ROM
    CM9
    Thanks a lot man, was waiting to pull the trigger.
  6. #6
    Quote Originally Posted by Weirdo0815 View Post
    i heard they fit but there is a bugle where the battery sticks up a little
  7. #7
    Quote Originally Posted by shibby View Post
    This is true but when you buy the Verizon branded extended battery, you get a battery door that fits the bulge... the only problem is that the door says Verizon on it, not Sprint.
    Current Device(s):
    Asus Nexus 7 16GB
  8. #8
    I do need to correct this statement... Although you do get a bigger door, you will need to cut two of the snap-in clips off the door to make it fit the Sprint GN. The two clips are to the right of the battery (when looking at the phone from behind). It shouldn't affect the back staying on the phone, especially if you're going to put your phone in a case.
    When I get a chance, I will take a pic and circle the clips you'll need to cut off. Shouldn't be more than say 30 minutes...
    Current Device(s):
    Asus Nexus 7 16GB
    Thanked by:
    xdalaw
  9. #9
    Default
    You buy the extended battery and door from without having to make any alterations .
    sent from Evo4G using Tapatalk
  10. #10
    Default
    Quote Originally Posted by Mercury81 View Post
    Or you can still have a thin phone with modifications... and not a gay hunchback...
    skinnhc and drewood31601 like this.
  11. #11
    I got the verizon battery today no the back did not fit but i was able to get the sprint one to fit and a bodyglove case too. and I only paid $25 for the battery, The case does fit tight so tight that it is hard to get off and I am thinking of taking the battery back it's only 350mah over stock.
  12. #12
    Posts
    Global Posts
    135 Global Posts
    ROM
    CM9
    I got the verizon one today too. The cover didn't fit that well. I'm gonna return it tomorrow and wait it out to see if sprint sells an extended battery.
  13. #13
    I might do that too,It's only 350mah over stock I just don't think it's that big of a deal but I love the phone.
  14. #14
    I just check out the battery the stock is 1850mah and the verizon extended one is 2100mah and that is only 250mah,So I don't think I am going to keep it I mean 250mah can't make that much of a difference can it?
  15. #15
    Default
    250 mah is good for an hour or so... for not a whole lot of bulk...that is plenty!
  16. #16
    Warning: Pictures of Naked Phones Are Included!
    Here are the pictures I promised to put up... sorry it was a bit more than 30 minutes or so... life got in the way.
    My Verizon Galaxy Nexus:
    My Verizon Galaxy Nexus Extended Battery Door:
    The Sprint Galaxy Nexus:
    Mostly for reference, the Sprint Galaxy Nexus standard door:
    You'll see in the first image that I point out the reason why the modification is needed. That is because the indents for the battery door snap-in things (i don't know the technical term for them lol) on the Verizon GN is in a slightly different position on the Sprint GN. You will need to cut off the one problematic snap-in thing on the door to make it fit (which I point out in the 2nd picture). Other than that, all other snap-in things match positions for the two phones.
    Also, the Sprint GN is black in color and the Verizon GN's darker grey / gun metal color. Just in case you were wondering... I didn't realize the colors were different until I had them sitting side by side.
    Current Device(s):
    Asus Nexus 7 16GB
    Thanked by 5:
  17. #17
    Posts
    Global Posts
    135 Global Posts
    ROM
    CM9
    I cut the tab and there seems to be a gap on the right side still. I wonder why.
  18. #18
    Mobius360's Avatar
    Posts
    ROM
    Stock 4.1.1
    Default
    Quote Originally Posted by kesquivel View Post
    I'm ready to go get this phone but it sounds like the battery life is the same as my Epic 4G. I just want a Galaxy Nexus Maxx and I'd be in heaven. Really wonder how the new Evo's battery life will compare.
  19. #19
    I'm averaging about 14 hours right now its a lot better battery wise than I expected.
    Thanked by:
  20. #20
    call sprint today and get the google nexus extended battery for free, well you pay shipping and tax.
  21. #21
    Default
    Quote Originally Posted by climbamtn View Post
    Yup! Already got my free battery
    Sent from my Awesome Galaxy Nexus
  22. #22
    Quote Originally Posted by acr456 View Post
    Order mine this am. Be here this week I was told.
    Sprint Galaxy S3 - White - Android 4.1.2
    Sprint GNex - Android 4.2.1 (Backup)
    Asus TF700T - Android 4.2.1
    Motorola Xoom - Android 4.1.2 (Backup)
  23. #23
    Default
    Same here they ship out today and should be at our door by wednesday
  24. #24
    Default
    -high 5- lol
  25. #25
    Hmm...I just called and they said it is only for new lines of service.
