I've been using my Gnex for a couple of weeks now (got it on preorder) and typically get between 16-25 hours on a charge.
Unfortunately, there is a fair amount of misinformation going around. Instead of starting from scratch, I'll add my own notes to the list Gekko put together. It's a good list, but contains some information about older phones that no longer applies to the Samsung Galaxy Nexus (Gnex.)
Originally Posted by Gekko
Battery Tips
1. WIFI, GPS, BT, Hotspot, (LTE) all set at OFF (mostly toggled using Android Power Widget). turn ON only as needed. use Wifi@Home App to automatically turn on and connect with Wifi when at home.
Actually WiFi is preferrable to 3G or 4G networks unless you get bad signal. The best situation is to leave WiFi on if you are around a good WiFi network most of the day. However, having the phone constantly switch between networks if you move around a lot or are in a bad network area will be a drain.
I read in many places that turning GPS off will not save battery life unless location services are using the GPS. You can leave the GPS set to on and it will only drain battery if you bring up Maps or some other navigation app that uses the GPS. I experimented with the GPS setting heavily during a recent road trip and found this to be true.
2. Brightness set to very low (slider set to extreme left under check box). this is plenty bright for me.
Good advice, but many people do not realize that the Super AMOLED display on the Gnex uses next to no power to display black pixels, reference: . White is the worst case. The EVO 4G and other TFT phones use a back light which uses the same amount of power no matter what is being displayed, turning down the brightness was the only option. With the Gnex (and any AMOLED display) the best advice is to use dark and/or black backgrounds. If an App (like Tapatalk) has a "Dark" theme, use that. Use Black Google (). Little changes can make a big difference in the amount of power the display is using.
4. No Live Wallpaper. not sure of this makes a difference but i have my own graphic anyway.
Good advice, Live wallpaper is sure pretty, but it means the CPU and GPU are in constant use when you are looking at your home screen. Turn 'em off.
5. No Data intensive constant data hungry widgets/apps constantly running. i wiped News and Weather App. uncheck them for Prefetch auto sync and set to 0 stories. i will get my data from the browser fresh as needed. i have no updating widgets other than 1 home weather city with the nice big beautiful Fancy Widgets HTC-Style Clock/Weather default widget i keep with auto refresh at 1 hour and Refresh on Unlock with 15 minute min interval. i have 1 GMail PUSH account that i set up and is always on.
Good advice, and I'll add another to the last point: You can set up Google Mail to retrieve several other email accounts for you. That means you can use just one main account on your Gnex and have mail from many accounts all pushed to the Gnex. Saves time looking through multiple mail boxes as well. You can even choose which account to send any messages From when you compose or reply to email. Very handy.
To set this up. go to Gmail in your computer's browser, and select "Settings" and then "Accounts and Imports" tab. Add as many accounts as you wish, I think it was originally limited to 5 accounts.
6. Stay signed out of everything - G+, Latitude, Messenger, GTalk, FB, Twitter. Everything! i don't use this stuff anyway. as noted before - let GTalk run in the background for PUSH Gmail but always sign out and uncheck auto sign you in.
A bit heavy handed, as it pretty much eliminates the usefulness of the smart phone. And Gmail and GTalk use very little power unless you have friends/colleagues who are constantly sending you messages.
7. Vibrate is ON for Calls and Texts. Vibrate is OFF for emails. all Haptic Feedback and Touch sounds - Keyboard, Screen, etc. is OFF.
I turn Vibrate off, period. It's rarely any more useful than the sound notifications and eats a bunch of power.
8. i DO NOT use a task killer or kill tasks with the Manage Applications Panel. nor do i use "Juice Defender" type apps.
Very good advice. Task killers became useless with Froyo (Android 2.2), and using them on Ice Cream Sandwich can do more harm than good. If you have an App that is behaving so badly you need to kill it on a regular basis, then you should consider eliminating that App or finding something better to do the job.
However, if you really are picky about tasks running in the background here is a tip I find most people aren't aware of. On ICS when you touch the "Application List" button to switch apps, you can swipe any app to the left or right to remove it from the list. This actually removes the app from the active apps in RAM. You can verify this for yourself by downloading a System Information app that shows active apps and RAM usage. Swipe a few Apps from the "Application List" and you will see that RAM has freed up.
This is totally unnecessary as Android does a much better job of deciding what Apps to keep in RAM and when to remove them for new Apps being run. If you honestly believe you are smarter than the team of people at Google developing Android, then by all means use this mechanism to keep apps out of the way.
Just don't use task killers, ever.
9. realize that streaming any audio and/or video will kill your battery very very fast.
Of course, but don't let that keep you from enjoying your phone's capabilities. Just watch battery usage while you are watching cat juggling videos and other productivity stuff like that
10. per XDA thread NFC appears negligible on battery life since it is only capable when display is on - so i just leave it on.
I still leave it off as I am not sure of the security of the feature yet. I hate to think someone could use it to steal data from my device without my knowledge. I turn it on if I want to share something, and then turn it back off.
There's really no such thing as being too secure these days.
11. put phone on charger every night before going to bed. you need to recharge and so does the phone.
Also remember that these batteries are best between around 30% to 80% charge. Charge it up when you need to, but don't worry about it until it drops lower than 30%. Charging it every time it drops to 60% is not productive.
And I do believe most people are playing with their new phones so much that battery drain is well beyond what it will be in a couple of months after the novelty has worn off and the begin using the phone like they did their previous phones.
When I first got my EVO 4G it became my primary browser because I could sit in the recliner and surf the web, read mail and generally have fun. This was before I owned a tablet. Battery life was rarely 12 hours between charges. Once I got to using the phone as a phone and productivity device, I typically got up to two full days between charges.
I expect the same will occur with the Gnex, unless a phone is defective.
@wrecklass
Some great points. Regarding services like gtalk, g+, push email.... people shouldn't not use them just because they think they are saving tons of battery by doing disabling them. If someone doesn't use a particular service then yes it makes sense to disable them but things like gtalk that use push notifications, having it signed in all the time really doesn't make a dent in battery life unless one is using it constantly (and in that case it's something useful to them).
With my usage I can easily get a day out of this phone and that is with using it for music streaming, leaving gtalk signed in all the time, g+ running, gmail set as default....
A couple phones ago I stopped watching the battery all the time, I throw it on a charger whenever I am near one at a desk I might be sitting at. I don't worry about things like "conditioning" the battery cause if you think about it, unless something is really wrong with either the phone, how it's setup or the battery, something like conditioning is not going to make a phone that lasts half a day somehow last a whole day. With all that said I now I stress much less about my battery performance.
I was having horrible battery life. So I went to a sprint store, and they swapped out my battery. which has seemed to help. It no longer gets as warm as it did before, it seems as though the battery was defective. The rep said if the same problem persists to just come back and they'l swap out my device for a new one.
I've only had my GNEX for about a week now, but so far I'm generally getting about 14-16 hours with moderate usage before it gets below 25% (except for the one day my kids played angry birds on it for an hour or so).
My previous phone, an HTC Hero with CM7 would easily get 35-40 hours on a single charge. Before that, on stock HTC I would do good to get 14 hours on a very good day.
I'm still trying to decide if I should keep the stock ICS on my GNEX or if I should switch to CM9 to see if there is any benefit to the battery life. I suspect it won't be as dramatic a difference as it was for my hero, though, since the GNEX does not appear to have a bunch of Sprint's undeletable, unstoppable crap that the Hero had.
Of course, I still look back to my old dumb phone prior to getting the Hero and remember how I only had to plug it in once a week. I don't mind pluging in every night, but it is a little stressful when I have to worry about whether or not I will need to charge it some during the day if I expect to be out late that evening.
I have had mine for over 2 weeks now and the battery is doing good.
Lasts all day with normal use.
If I will be going out in the evening and know I won't get back to a charger until late, I throw it on the one I have at work for an hour or so to tide me over.
Question: Does Vibrate really use alot of power?
I have to keep the sound on my phone off while at work so I need something to let me know if I have a message or a call.
Thanks.
Mav.
Scissors cuts paper, paper covers rock, rock crushes lizard, lizard poisons Spock, Spock smashes scissors, scissors decapitates lizard, lizard eats paper, paper disproves Spock, Spock vaporizes rock, and as it always has, rock crushes scissors.
Thanks.
Mav.
Honestly, I wouldn't imagine vibrate uses that much power....unless it going off all the time. My only thing is I never feel it, I wish it shook as much as some of the old "dumb" phone. I can hear those things from across the room.
If by some chance I helped you out, please be so kind as to hit that thanks button. You'd be a lot cooler if you did.
I throw my phone on silent when im at work, vibrate when im going to bed (though it only really vibrates when I get a text or call) and audio for everything else.
Anyways, battery has been good to me...can go all day with some light email, fb, text/call and some spotify streaming with no problem.
Still need to try it out with heavy music streaming though since all I use is Spotify music wise and that can eat battery up.
Had my battery tested at the Sprint store on their Cadex machine...tech there said it was the highest, Excellent...but still not sufficient for me. Tried all the forum fixes here(thanks wrecklass!)...will limp along until Android store has a Sprint version of the 3800 Seido...
This is why I love lightflow. It has a scheduling feature that allows me to turn off notifications at night. So no bothersome email or text alerts at 3am. But the phone still rings, but any call at that time of day is usually an emergency.
I agree about how weak the new vibration feature is in smartphones. They use a tiny motor with a weight that is out of balance to make the vibration, which uses a lot of energy. Newer phones save battery by using very small vibration motors.
Got this phone about a week ago and have loved the hell out of it. One thing I did not love however, was the battery life. After rooting and putting CM10 on there I found I was getting about 6 hours on the stock 1850 battery, and this was connected to wifi most of the time. After much tinkering, I have come to a solution which is working for me.
ROM- Cyanogenmod 10, latest nightly build
Kernel- Trinity 1344-384
Governor- Conservative
Pro tip- Also flashed a Battery Booster zip
So far at 70% with just a hair over 6 hours off the charger. Very happy with this and I can't wait to see what eventually getting the extended battery will do for me. Hope this helps someone.
What did you do to get battery life like that? Or is that an extended battery? Either way, I got my Galaxy Nexus yesterday and did something that I almost never do...I actually fully charged the battery before I started using it! Well, since I spent most of yesterday evening (and part of this morning) moving all my data from my old Optimus S's SD Card and installing apps it was connected to USB until this afternoon. Well, here are my battery stats:
Well, I forgot to take that third screenshot before plugging in my phone so the 'screen on time' may be a bit less than what is shown but, everything else was taken when I noticed my phone hit 1%. I'm about to call Sprint to get a 2100 milliamp-hour battery. I will admit that I went into this knowing that the battery life wasn't exemplary and my old phone, after nearly two years, was just about this bad concerning battery life so I'm used to it, I carry a spare micro-USB cable and a charger block everywhere ^_^
Oh, I should note, I'm running AOKP's JB build 4 as my current ROM and I haven't changed the Kernel from the one that came with AOKP.
So I picked up a 2100 maH battery and it's about the same if not a little worse than my 1850 battery. Dafaq? I'll edit this post later with screenshots to show you guys exactly what I mean, but I could get a comfortable 20 hours of moderate use out of 1850 but 2100 only gets 20 on light usage. It did take about 3 weeks to a month for the first battery to get to that level, but still. Any thoughts?
After a little use, I think it gets better. Try to suck it nearly dry a few times before you charge it.
Also, you can try clearing your caches (regular and Delvik) and let it "reoptimize" your apps. Not sure if that helps, but it can't hurt.
My phone gets so hottttttttt when I charge and use at the same time.I came from an iPhone and was used to it taking an hour to charge and being able to watch Netflix for 8-10hours consecutively. my nexus gets so hot at times I take the batt out and let it cool cuz I'm worried it can harm the hard ware.the battery sucks,and movie editor won't work and my reception sucks.I'm 6days past my exchange deadline and am going to try and talk sprint into letting me upgrade to the galaxy3......like the screen and phone in gen but I want better quality and know this phone will take a crap on me in the future with it getting so hot
I just got a Galaxy Nexus last Friday as an exchange from an LG Viper. My service range has gone way down, I drop 3G constantly, my battery runs hot even on text messaging. This phone worries me that it could have a meltdown at anytime. My old EVO Shift has better service than this Nexus.
Sent from my Sprint Galaxy Nexus using Tapatalk 2
Current Device: Sprint Samsung Galaxy Nexus Jelly Bean 4.2.1
Previous Devices: HTC Evo Shift 4G & iPhone 3GS 16GB
Portions of this page are modifications based on work created and shared by the Android Open Source Project
and used according to terms described in the Creative Commons 2.5 Attribution License. AndroidCentral is an independent site
that is not affiliated with or endorsed by Google.
