Results 1 to 6 of 6
    Seven2k's Avatar
    Posts
    Global Posts
    379 Global Posts
    Default NFC slow compared to Nexus S
    THought I would ask and see if anyone else saw the difference in speed in NFC transactions . I wen to the market last night and I have used my Nexus S before at checkout and it went smooth almost instant when paying with NFC. Last night with me new GNex I stood there for about 30 seconds moving my phone up and down the little pad thinking that my case was blocking the signal. I removed my case fast cause line was behind me and then I got the "Sending" with the radio signals. ANyone else have this issue?
  2. #2
    Default
    Nope its actually been faster on gnex then my ns4g I even used it thru a otter box
    Sent from my Sprint Galaxy Nexus CDMA using Tapatalk 2
    Seven2k's Avatar
    Posts
    Global Posts
    379 Global Posts
    Default Re: NFC slow compared to Nexus S
    ok..ill try another place and make sure its not my phone.
  4. #4
    Default
    Mine works just as fast as before like instant
    Sent from my Sprint Galaxy Nexus CDMA using Android Central Forums
  5. #5
    Default
    I noticed that you have to actually lay the device on the cc machine with the nexus. When I had a nexus s I just had to hold it above without touching it.
    Sent from my Transformer Prime TF201 using Android Central Forums
    Seven2k's Avatar
    Posts
    Global Posts
    379 Global Posts
    is there a reset for the nfc itself?
